irab88's '93 SR5 conversion thread
Old 08-08-2012, 08:23 AM
  #81
thefishguy77's Avatar
Irab I have been reading a lot of stuff on power option swaps and you seem to be the resident expert. I was wondering if you could help me out with a question about power door upgrades. I have a 93 p/u and and 89 parts truck. My parts truck has full power options and I was thinking about just swapping the doors over for ease of setup and because my 93 has rust showing in lots of small areas. If I do the door swap will it be easy to run the hot lead(s) and get both windows running on the drivers side switch? passenger switch should work as well. also same question for the power mirrors and locks. Thank you for doing all the research and letting us less technical savy guys learn from your experience.
Old 08-08-2012, 08:51 AM
  #82
irab88's Avatar
try it. that's what i do. find out what wires go where, take the door panels off, and put something together.
the thing about the door switches is that they run to a single control box not located in the doors. mine is a few relays in the center console. you may have to run a few more wires than just a ground and hot
Old 08-08-2012, 08:56 AM
  #83
will try and get after it this weekend thanks for all your work
Old 09-01-2012, 04:26 PM
  #84
irab88's Avatar
worked on my interior today.
old radio/hvac trim
first up, this is the ignition light that i got up and running. works well. it stays on a few seconds after you close the door.
i realized i had a lot of accessories, so i added a terminal block (20 amp fused)
and the new bezel
back together
Old 08-25-2013, 07:25 AM
  #85
Rockjump2fish's Avatar
The power door locks are a great option
How did you wire in the brown and white wires that say they are supposed to go to some ground? (Vehicle hull)
Thank you and love this site
Old 08-25-2013, 08:59 AM
  #86
ChefYota4x4's Avatar
Looks nice, Ian. Hey..... You in 4WD? Lol
Old 03-13-2015, 10:35 AM
  #87
91toyota907's Avatar
Originally Posted by irab88
i don't know what you're talking about...
besides, my truck has roll-up windows already. that means i would need entirely new regulators...
...like these
Was that literally all you needed for the power windows??
Old 03-23-2015, 06:08 AM
  #88
irab88's Avatar
yeah, that bolted right in in place of the crank regulator. two wires to the motor (+/- for up, -/+ for down) and the circuit for the buttons as shown below.
it has 4 bolt holes, while the crank has 3. i used the same 3 bolts (omitting the 4th) in the new regulator and it works fine. i should have put in a 4th to be totally secure, but whatever
edit: cleaner circuit design:
PNWrider
10-30-2015 08:14 AM
gary4runner
09-24-2015 12:53 AM
Robojd1
23
07-21-2015 01:43 PM
Rkellerman
07-12-2015 08:42 AM
crashburnoveride
07-10-2015 06:39 AM
Quick Reply: irab88's '93 SR5 conversion thread
