Internal coolant leak
Old 11-26-2012, 03:08 PM
jehagado's Avatar
My 92 pickup, 22RE, 188k miles has an internal coolant leak.
Oil is clean (no antifreeze) antifreeze is being burned and going out exhaust.
I bought a Snapon cooling system tester on Ebay (very cool tool).
With engine off, pump to 10 PSI, drops very slowly.
With engine running, pump to 10 PSI, drops slowly (just a smidge faster then engine off).
Has the head gasket failed or have there been other failues (in block or head).
Thanks, Jerry
Old 11-26-2012, 03:10 PM
HighLux's Avatar
More than likely a head gasket. Check the plugs.
Old 11-26-2012, 08:39 PM
TNRabbit's Avatar
With the engine off, can you HEAR where it's leaking? You should be able to. Pull ALL the spark plugs & listen while the pressure drops, then turn the engine over & if there's a leak into the system, it will blow it out the offending plug hole.
Old 12-03-2012, 08:54 AM
annoyingrob's Avatar
Alternatively you can use a leakdown tester in each cylinder and listen to which one is bubbling into your coolant.
Blamalam
03-12-2022 07:34 AM
SubiKing
08-21-2021 03:57 AM
WellsR
12
07-31-2015 03:27 PM
itzmywife's
07-25-2015 04:55 PM
Avenged
07-09-2015 07:55 AM
Quick Reply: Internal coolant leak
