Intermittent Loss of Throttle/Engine on 22RE
Old 05-08-2008, 11:01 AM
maxwe001's Avatar
this is a simple problem and easy to diagnose its your selunium rectafire
swap it out and that truck will run like it just came off the show-room floor dont thank me im just glad i saw what your problem was before you went of and spent millions of bux on something so easy
Old 05-08-2008, 06:11 PM
iamsuperbleeder's Avatar
the what? your tuck has a flux capactitor too doesn't it...
Sounds like the voltage regulator built into the back of the alt. is shot. I've had 3 er 4 go bad, and all went intermentent like you're describing. Hard to show when bench testing an alt. at a shop. I'd see if you could find a used one that you know works, and see what happens. If it solves the problem with the other alt. in, then you know what you have to do.
Old 10-28-2008, 01:27 PM
Toyvana's Avatar
Put a new fuel filter on last weekend and it's running a lot better now...only drove it from Fri-Sun but I'll have to wait and see if it stalls again.
montanatruck
02-26-2017 07:07 AM
JaredL
03-28-2016 09:08 PM
Tacoma1313
08-17-2015 05:44 PM
nate2919
08-06-2015 04:00 AM
landrunner
08-05-2015 09:18 PM
Quick Reply: Intermittent Loss of Throttle/Engine on 22RE
