intake support arm HELP ASAP 22re
Old 09-23-2007, 08:37 AM
gametom's Avatar
so i was putting the intake back together and i don't remember where this was attached because when i took the intake off it was just hanging (the previous owner must have done some intake work) o it's a 91 4runner 22re 5speed
Thanks
Old 09-23-2007, 09:01 AM
8yota9's Avatar
it gose down the side of the fender above the stering box ataches to the side of the intake box and the side of the wall.
Old 09-23-2007, 09:05 AM
Staff
DeathCougar's Avatar
Sorta....
It attaches to the middle of the intake at the top, and the pass side motor mount on the bottom.
The motor mount should have an open hole, hence the welded but on that intake support bracket.
Old 09-23-2007, 10:09 AM
gametom's Avatar
is this where it attaches
Old 09-23-2007, 10:34 AM
Staff
yes. From there to the motor mount.
Old 09-23-2007, 10:36 AM
gametom's Avatar
Sweet Thanks
Old 09-24-2007, 06:45 AM
4Hummer's Avatar
Picture is worth a thosand words
Old 09-24-2007, 11:20 AM
Staff
I love that you have an oil COOLER mounted next to a block HEATER lol.
Old 09-25-2007, 06:50 AM
4Hummer's Avatar
Figured it was the best place to put it. that way in the winter the Oil in the Filter will be a bit warmer on startup, along with the Coolant.
It gets to minus 30C here in the winter.
Old 09-25-2007, 06:57 AM
gametom's Avatar
ya that's where i put it.
by the way i like the red 22re.
maybe i should make one ether blue or yellow.
what kinda paint did you use on the block?
Thanks for the help
Old 09-26-2007, 05:29 AM
4Hummer's Avatar
Thanks for the help
Plain High Heat engine paint. Motomaster Brand (Canadian Tire)
Red and Grey.
RatOmeter
10-22-2015 03:17 PM
RobotMoose
Diesel Swaps
08-02-2015 11:00 PM
kirkrunner
07-27-2015 07:59 PM
1994toyota
07-17-2015 03:03 AM
Quick Reply: intake support arm HELP ASAP 22re
