Intake Manifold Upgrade
Old 12-20-2010, 01:43 AM
Fossilized
Staff
dropzone's Avatar
Originally Posted by Jeffrey154
I was thinking about going with pacesetter ceramic setup, but i see alot of people using the downeys
Downey succumbed to poor economic conditions a while ago. You will either find used or might get lucky and find NOS.
Old 12-20-2010, 03:33 AM
Jeffrey154's Avatar
I think i'm just gonna end up using pacesetter, but i'm not quite ready to cross that road just yet. We'll see what happens.
Old 12-21-2010, 11:43 AM
Jeffrey154's Avatar
UPS needs to hurry! I'm ready to get some grease under my nails.
Old 12-21-2010, 03:49 PM
Jeffrey154's Avatar
I noticed that their is a port on the engine (the third one from the left in the pic on the last post) that isn't on the pictures for the new manifold. Will this get covered by the new manifold, or do I need to get some kind of blockoff plate for it?
Old 12-21-2010, 04:19 PM
  #25
xxxtreme22r's Avatar
Not sure what you mean by third one on the left. You mean the port that is in between the #2 and #3 intake port? Pretty much the one in the middle? If so that's I believe is the water supply or return for the water plate on the bottom of the manifold. Not sure if the factory part will fit with the offy intake on there or not. Haven't looked that far into it as I just planned on using all the block off plates in the LCE kits when I do mine. Which eliminates the whole thing under the intake and a few others.
Old 12-21-2010, 05:11 PM
  #26
Jeffrey154's Avatar
from the left, their is the egr port, an intake port, then a small square looking port above a stud. The small square looking one is the one that i'm talking about
Old 12-22-2010, 11:20 AM
  #27
JamesD's Avatar
Pacesetter headers are junk. Very thin walled tubing they use. LC has one but it is not cheap.
James
Old 12-27-2010, 09:35 AM
  #28
Jeffrey154's Avatar
So the install is almost done, i'll have some pics posted when I find my camera... The one thing i'm trying to figure out at this point is where is the best place to mount the fuel pump at. I want to keep it in the engine bay, but I read that it is better mounted closer to the tank.
Old 12-27-2010, 11:58 AM
  #29
MudSir's Avatar
holley fuel pumps are designed to push fuel not pull it. As close to the tank as you can. PS put a cut off switch hidden so if you want you turn the fuel pump off so no one drives off with your toy.
Old 12-29-2010, 09:48 AM
  #30
Jeffrey154's Avatar
I read it supposed to go as close to the tank as possible, but i'm looking more for suggestions on a specific location that wont leave my pump soaked in water and mud.
Old 12-29-2010, 10:15 AM
  #31
not sure on the dimensions of the holley pumps, but you can always put the pump into one of these:
http://www.radioshack.com/family/ind...goryId=2032276
Old 12-30-2010, 02:08 PM
  #32
Jeffrey154's Avatar
Just finished hooking up everything!!! The truck started up like it was new. The only issue that i'm facing now is the idle speed. I've got the mixture screws backed out about half a turn, the regulator is set at 3 psi (tried settings everywhere from 1-4psi), and my idle is sitting at about 3600 rpm. I have a feeling that it needs to be rejetted, but to be honest, I have no idea where or how to start on that one. All things aside, IT STARTS AND RUNS!!!
Old 12-30-2010, 03:16 PM
  #33
make sure your throttle linkage isn't getting hung up anywhere or that you don't have a vacuum leak somewhere.
Old 12-30-2010, 05:56 PM
  #34
Jeffrey154's Avatar
Throttle linkage is good... I'll check the brake booster line when their is light out tomorrow
Old 12-31-2010, 04:19 PM
  #35
Jeffrey154's Avatar
Double checked the linkage... was a lil too tight... she's almost running like a dream now. just gotta finish fine tuning it. Thank you for all of the help and Happy New year!
Old 12-31-2010, 05:00 PM
  #36
good to hear you got that sorted out. Keep an eye on the throttle return spring too, I had to add a supplemental spring to help return the throttle as I think the factory toyota one on my linkage is worn out.
Old 01-01-2011, 12:19 AM
  #37
Jeffrey154's Avatar
had to do that on my last truck... might think about doing it on this one before it becomes an issue
Marsheen
02-17-2016 12:29 PM
Anthony Lee Mathis
09-15-2015 07:22 AM
shalom
09-08-2015 10:02 PM
ManzDaKlown24
08-22-2015 10:25 PM
Quick Reply: Intake Manifold Upgrade
