installed new O2 sensor still have problem
Old 04-07-2007, 02:27 PM
gixxer_grand's Avatar
i had a bad idle and bad fuel milage i thought it would be my o2 sensor so i changed it i still have a bad idle (800rpm sometimes 750rpm) i didnt take the truck out yet so i dont know about gas milage does anyone else know wut else can cause this low idle?
Old 04-07-2007, 03:19 PM
krash2k77's Avatar
if in fact u are running that rpm speed u are doing just fine.. that is normal... if it is wayyyyy lower like almost dying then keep checking around and i will see what i can see. also have u checked the TPS? May be that but if u are 750 800 u are right on it..
Old 04-07-2007, 03:26 PM
slacker's Avatar
timing
o2 sensor
TPS
coolant sensors
are ALL major factors in loss/fuel economy
I have just went threw 2 years of 300K per tank woes .. replacing sensors , checking , tweeking .. ahhhh .. so I'm bald now .
I replaced almost every sensor .. EVERYTHING .. except airflow meter and computer .
I did some checkin' . I had the Original throtle body , which I cleaned , and thought I would set it up the TPS .. as per the factory specs .
problem is .. I cant get a consistant reading on the meter , because of the throttle shaft movement . my throttle body is toast ..
so I check all 3 that I have .. same thing .. I check the supra throttlebody im building .. no play . DANG ..it's perfect ...
I check with toyota .. part # 22210-35150 replacement .. NO LONGER AVALIABLE ... this sucks ..
sorry for the long wind .. but I forund a good throttle body ..finally .. set it up with my ohm. meter , and seems to work good now ..
3 days now and I have already noticed an improovement in my fuel economy .
Old 04-07-2007, 06:10 PM
longhungsilver's Avatar
Originally Posted by slacker
timing
o2 sensor
TPS
coolant sensors
What was your tps like when u took it off outa curiosity? Mine doesnt snap back all the way when i wind and release it.. it always snaps back slowly and to a different spot.. I cleaned it up and I think it worked better for a bit but now i think its back to its old tricks...
Old 04-08-2007, 06:41 AM
slacker's Avatar
it was real stickey as well ... I used some pen.fluid (very little) on it and freed' it up ..
Old 04-08-2007, 08:46 PM
did u try runnin it on the truck once it was freed up?? I presently am using it after lubeing it and i found it good for about a day (unless it was my imagination) and now my idles a bit erratic again... (i am waiting on a new tps i ordered off the net)
Steven.m.paulk
06-07-2020 10:45 AM
live4soccer7
05-11-2016 06:52 PM
dzldust
7
10-06-2015 05:39 AM
hiluxinargentina
09-30-2015 05:51 PM
voiddweller
09-28-2015 11:21 PM
Quick Reply: installed new O2 sensor still have problem
