Ignition wiring diagram?
Old 03-04-2013, 02:54 PM
Jagger_MeisterJE's Avatar
Exclamation Ignition wiring diagram?
I can't seem to find one anywhere! Searching it didn't come up with any good clear ones. Does anyone have a coloured wiring diagram for the ignition switch to an 87 4runner? i plan to run a new 2 position key and push button, with a few other little options i just need the colour code so i can take mine apart. (Id keep it but it is worn out, and actually so bad if i start the engine the key cant turn it off!
Old 03-04-2013, 08:19 PM
Co_94_PU's Avatar
Just clean and refurbish it, but I've maybe already said that
autozone has diagrams, and the fsm also both in the wiring section and ignition switch section. FSM Be-11(pdf pg 1169) and pdf pg 1459
Server logged me out not going to retype the chart and color list, sorry. ST2 is pin 5 and I'm guessing your issue with the diagrams, none of the ones I have say it's color or destination either.
Sleaker
08-26-2020 06:03 AM
toyotamonster
3.4 Swaps
7
04-16-2020 06:02 PM
sanctfy
All Other Toyota Swaps
09-15-2015 02:52 PM
TDonkey
07-26-2015 10:14 AM
80Truck
07-24-2015 03:12 PM
Quick Reply: Ignition wiring diagram?
