IFS Rotor Torque Specs
Old 06-06-2008, 06:29 PM
rusche's Avatar
I'm in the middle of my brake job, putting on my new rotors, and I go to look for torque specs...
..and just realized the FSM I have is for a SFA.
Anyway, I need the torque specs for the 6 bolts inside the rotors if anybody knows them.
Thanks for the help, I'm putting on new rotors because my old ones were warped and would love for that not to happen again
Old 06-06-2008, 08:12 PM
Yota82's Avatar
the torque spec is PFT (Pretty F@#$%n Tight). As long as there is no crap on the mounting surface and they are all tightened the same, I wouldn't worry about the spec or warpage. Try like 70 lbs, that sounds good to me.
Old 06-06-2008, 08:59 PM
rusche's Avatar
I swear I read 47
Thats what they are currently torqued at
Should I go higher then?
Old 06-07-2008, 05:59 AM
InternetRoadkill's Avatar
FSM says 47ft-lb
Old 06-07-2008, 06:03 AM
Brenjen's Avatar
Torque to what the FSM says, don't just guess at it. They set torque specs for a reason.
Your brakes are an important safety feature for you & the other people on the road.
Old 06-07-2008, 12:39 PM
leebee's Avatar
you will find that they can warp due to having the lug nuts overtightened, especially if you run alloys. paint some anti-seize on the mating surfaces to facilitate easier removal for next wheel rotation.
lee
Leviticus6432
11-20-2015 05:06 PM
88sasturbotoy
08-11-2015 01:56 AM
rustym
08-07-2015 10:39 AM
colasurdo
07-18-2015 07:06 AM
colasurdo
07-17-2015 08:28 AM
Quick Reply: IFS Rotor Torque Specs
