IFS BJ spacers, Upper & Lower Balljoint removal / install
Old 04-13-2014, 03:43 PM
  #41
Mauk's Avatar
Originally Posted by AZ89LONGBED
I went with OME Dakar rear springs, probably 2-2.5 inches of lift...
did the ome springs fit right in or was there modification needed?
Old 10-09-2014, 08:29 PM
  #42
AZ89LONGBED's Avatar
Originally Posted by kai32
I was thinking about installing a small lift with some BJ spacers on my 4runner soon and was wondering how hard of a job the grinding is on the a-arm? If i dont have experience with an angle grinder is this something i will be able to do?
KAI32-- The grinding was minimal. Grind off some metal, test-fit the spacer and see if you removed enough material from the A-arm lip, repeat as necessary. Much simpler than you are probably imagining.
Old 10-09-2014, 08:31 PM
  #43
Old Man Emu leaf springs bolted directly in. IMHO the best aftermarket springs around for Toyotas.
Old 10-10-2014, 10:21 AM
  #44
RAD4Runner's Avatar
+1 for OME. Just watch out for clearance between fuel tank pinch weld and spring pack clip bolt head.
See what Defrag and Ruined Adventures put theirs through.
Old 04-30-2016, 02:36 PM
  #45
86bedlesstoy's Avatar
5 years later, how does it ride? Any replacement of idler arm?
Old 07-15-2017, 10:49 PM
  #46
6 years later
Still have the pickup, and still impressed with the OME suspension. Had a little wobble in the front end that was due to out of balacne tires, and replaced the super cheap replacement idler arm with an OE part, no more wobble.
Old 07-16-2017, 07:20 AM
  #47
RAD4Runner's Avatar
Good to see this. My driver side BJ's grease/dust jacket has now started to leak and I see a little vertical play. Ordering replacements soon.
How was the condition of your upper BJ's compared to the lower ones? Reason I'm asking is I'm on a tight budget. Wanna replace the load-bearing AND obviously bad uppers first, then lowers later.
icentropy
09-16-2020 02:47 PM
lledwod
08-30-2016 01:03 PM
09-04-2015 09:27 AM
HaydenConQueso
07-12-2015 05:22 PM
akaphilly
07-09-2015 02:27 PM
Quick Reply: IFS BJ spacers, Upper & Lower Balljoint removal / install
