IFS BJ spacers, Upper & Lower Balljoint removal / install
Old 10-23-2011, 10:58 PM
truckmike26's Avatar
Most excellent. How much droop travel is left over? Are the balljoints now the new "limiting straps?"
Old 12-06-2011, 08:15 PM
Jüles Bästard Runner's Avatar
Nice post man, I was wondering to find one exactly like your´s as I bought the 2" BJspacers that comes with a dropdiff and Sway bar drop kit, I´m installing it on this week as soon as I get my Procomp shocks, I´m deffinitely posting a thread of this work for u guys.
Old 01-04-2012, 05:02 PM
AZ89LONGBED's Avatar
Good point. Right after it was finished I had very little droop left. I then relaxed the t-bars a bit, the previous owner had them cranked & that helped a bit. With the hubs locked, there is vibration at speeds above 45, either in 4x4 or 4x2. I used to be able to cruise at 50+ without any noticeable vibes from my front end before with the hubs engaged. A bit more binding at full-lock as well. Diffdrop is prolly in my future.
Once the rear settles, I will adjust the t-bars down a bit more, and enjoy the extra wheel travel.
Old 01-07-2012, 04:30 PM
On my truck, I checked beforehand and it looks to be a CV binder. So I got the diff drop kit because I'll probably need it. And the torsion bar adjusters are just jack screws -- sounds funny! But seriously, it's just up and down.
Old 02-19-2012, 02:33 PM
  #25
Chaddly01's Avatar
Thank You
I just wanted to say thank you so much for this write up! I just recently purchased my first Toyota pick up. 1991 3.0 reg cab DLX. I have searched this site for over a month. I became a registered member. This is the greatest sight ever. Thanks again so much for this Im tackling this project in the next few days..
Old 03-01-2012, 01:46 PM
  #26
UPDATE: BJ spacers cause vibrations with the hubs locked, no two ways about it. A diff drop helps, but I am working on other solutions, like lowering the front of the diff and working on driveshaft angles
Old 03-02-2012, 06:21 PM
  #27
Have you tried adjusting down the torsion bars a bit? Maybe it's the one or two mm that will fix the vibrations.
Old 05-07-2012, 04:14 PM
  #28
trktwo's Avatar
tagging this, got started on this about an hour ago. got the shock and bumpstop off, 2x4 spacer installed. thanks for the great write up
Old 12-14-2012, 10:31 AM
  #29
Buck&DuckRig's Avatar
i know its been a long time but i was thinking about this lift and i was wondering if you ever jot the vibration fixed
Old 02-06-2013, 06:44 PM
  #30
1985YOTA4x4's Avatar
Great thread man, very detailed. I did the EXACT same thing on my '89 4runner up front (new upper/lower ball joints, BJ spacer, and OME nitrocharger)...I was going to do a write up but then it would be the exact same thing as this, so thanks. In the rear I did a 'zuk mod' with rear TJ coil springs - rides great with OME shocks all around and I've got another 2 inches of lift. I too will get 4.88 gears soon as I'm throwing 33's on. OME shocks are the way to go, my truck rides so nice
Old 04-20-2013, 05:37 PM
  #31
BuckNDuck--
I got the vibes down quite a bit using 4crawlers diff drop kit. While installing the diff drop I also redrilled the front diff mount tab to help with the front diff angle a bir more, and I can drive 35-40 mph in 4H without much vibration. The rear vibes are almost nonexistent, although I do plan on rebuilding my t-case at some point as the outputs leak a bit of oil and have a slight bit of play.
Haven't been too particular about it for the moment, as this truck is my 2ndary rig now. I picked up a 2013 F150 4x4 and have been crazy busy with work.
I'm going to add my air compressor install and rear bumper build in a bit.
Sorry it took me so long to answer your questions.
Old 04-22-2013, 04:19 PM
  #32
Slowey23's Avatar
Great write up, what size BJ spacers did you install and how far did you drop the diff?
Old 06-07-2013, 09:05 PM
  #33
They are 1.5" spacers from 4crawler. The front differential drop is probably an inch??
Old 06-30-2013, 05:50 PM
  #34
julsruls's Avatar
Very helpful. Ill be going this route but probably try do brakes and bushings and paint everything while im down there as well.
Old 10-07-2013, 03:41 PM
  #35
nuttynu's Avatar
Bump for great info
Old 10-15-2013, 01:57 PM
  #36
nuttynu's Avatar
Are any of you guys replacing the hardware bolts and but that came with the bjs to grade 8 bolt? Or are they good enough ?
Old 11-01-2013, 07:53 PM
  #37
The hardware supplied with a new kit should be plenty strong, but mine was a used set of BJ spacers so I needed new nylock nuts and decided for peace of mind to spend the extra 7 dollars for all new bolts as well.
Old 01-27-2014, 07:26 PM
  #38
hawaiiankanahele's Avatar
How many inches of leaf spring did u add?
Old 03-13-2014, 06:58 PM
  #39
I went with OME Dakar rear springs, probably 2-2.5 inches of lift...
Old 03-13-2014, 08:08 PM
  #40
kai32's Avatar
I was thinking about installing a small lift with some BJ spacers on my 4runner soon and was wondering how hard of a job the grinding is on the a-arm? If i dont have experience with an angle grinder is this something i will be able to do?
Quick Reply: IFS BJ spacers, Upper & Lower Balljoint removal / install
