Idler screw?
Old 11-11-2009, 08:34 PM
austinmacry's Avatar
Idler screw?
Does anyone know where the idler screw is? And which was to turn it to lower the idle? Also what is the proper idling rpm is for a 91 4runner manual 3VZE?
Old 11-11-2009, 08:42 PM
abecedarian's Avatar
Screw- turn in (clockwise) to lower idle, turn out (counter-clockwise) to raise idle:
(Screw is just barely right of center of image)
850 rpm's for idle speed.
Old 11-11-2009, 08:46 PM
awesome thats perfect thank you!
Old 11-11-2009, 08:47 PM
make sure you adjust your timing when you change your idle.
Old 11-11-2009, 08:58 PM
Im adjusting the idle because I just got done putting new plugs/wires and re-timing the distributor and the rpm is sitting at 1700. So your confusing me on the timing thing?
Old 11-11-2009, 09:03 PM
Timing is set at a particular idle speed. Changing the idle speed can change timing.
Both are rather intimately related- changing one affects the other.
So you have to set both: timing @ 10BTDC with idle @ 850.
Make sense?
Old 11-11-2009, 09:18 PM
Okay I understand what your saying except I dont know what 10btdc means.
Old 11-11-2009, 09:22 PM
ignition timing set to 10 degrees before top dead center (10BTDC)
Old 11-11-2009, 09:24 PM
Got, thats all pretty easy stuff thanks!
Old 11-11-2009, 09:30 PM
yep. set the idle, jumper the diagnostic plug and check / set timing, then set idle, and repeat until you have the idle and timing set.
Old 12-05-2011, 11:36 AM
ethemm's Avatar
What will come up when checking the diagnostic?
Old 12-05-2011, 12:42 PM
82toyotamike's Avatar
Does any one know why my idler screw keeps comeing unscrewd? And how i can make it stop?
Old 12-06-2011, 04:02 AM
TNRabbit's Avatar
It needs a new o-ring. Dealer or if you have the old one you can take it in to any parts store & get a replacement.
Old 12-09-2011, 06:47 PM
ethemm's Avatar
never mind i understand now
ladybugRC
458
08-21-2020 10:41 AM
zytra
01-24-2019 03:16 PM
hiluxinargentina
09-30-2015 05:51 PM
JookUpVandetti
09-30-2015 08:58 AM
charlie_fong
09-27-2015 10:06 PM
Quick Reply: Idler screw?
