Idle Surge Issues
Old 03-26-2013, 07:56 AM
  #81
ejlarson's Avatar
Bump.
Old 03-27-2013, 04:41 AM
  #82
SX200's Avatar
Originally Posted by lilgription
SX200 I took my TB off and removed the IACV and cleaned it and threw some air to it. Took care of all my issues. Try that and see if it works for you
Worked like a dream.
Thanks.
Old 03-28-2013, 07:15 AM
  #83
ejlarson's Avatar
Thanks.
Hmm. I reckon I will try this sometime in the future.
Thanks!
Old 04-09-2013, 03:09 PM
  #84
Mr. Coltone's Avatar
i have the surging idle and ive changed my TPS, IAC, vacuum lines, radiator, checked for vacuum leaks everywhere and nothing is working. i put a piece of duck tape over the hole the IAC puts air through and it idles alot different but still slowly surges. i cant figure it out and my fuel mileage went to crap and my motor is being worn down alot. I NEED HELP!!!!!!
Old 04-12-2013, 11:55 AM
  #85
LuczOr's Avatar
My old 93 had a surging idle and it turned out to be the idle air bypass (called auxiliary air valve in the FSM). I just bought an aftermarket one for cheap and replaced it and all was good.
Old 03-29-2015, 03:31 AM
  #86
Robbie2's Avatar
I have an 89 3.0v6 pickup the idle surge is temp related for sure I don't know where the temp sensor is or the egr valve can someone help me
smthwsn357
05-01-2024 07:28 AM
Sleaker
08-26-2020 06:03 AM
montanatruck
02-26-2017 07:07 AM
Alex Bessinger
08-31-2015 09:17 AM
greenbuggy
3.4 Swaps
07-23-2015 11:51 AM
Quick Reply: Idle Surge Issues
