Idle issues on my 22R
Old 09-08-2012, 07:27 PM
adeantoni's Avatar
Ok so a few weeks ago I ran my 87 Toyota pickup real low on gas. It has a 22R. On my way to fill it up it started idling really rough to where it wanted to die. A few days later I cleaned the carb, changed the plugs wires rotor cap fuel filter and air filter. It seemed to help for a little bit. But then it went back to idling rough after I would wind it out to about 4000 rpms. When i park it and start it back up a little bit later its fine. But once i wind it out again it started actin up again.
Then today i was drivin it and now it either idles really rough to where it almost dies, or it idles at 1500 rpm or higher, all the way up to just over 3000 rpm.
I have no idea where to even begin looking to try and diagnose the problem.
I NEED HELP this is drivin me crazy!
Old 09-08-2012, 07:36 PM
abecedarian's Avatar
Carburetor float level?
Needle valve sticking?
Old 09-08-2012, 07:58 PM
slow-mo's Avatar
Yes, definitely check the float level first. The fuel level is visible, or should be, in the sight glass.
The fuel level affects all of the carburetor circuits.
Old 09-08-2012, 08:58 PM
xxxtreme22r's Avatar
Subbed. Even though I have a weber and really good with carb's I had this issue at my last bog. Broke a timing chain shortly after. I don't think it's related to the timing chain, but who knows. Another thing I have noticed afterwards, is that my choke isn't automatically engaging. Pressing on the choke plates and operating the throttle gets it to engage, but it doesn't engage on it's own.
Old 09-08-2012, 09:07 PM
A couple things should happen with an automatic choke...
Cold start, step on the pedal and the choke plate(s) should be pulled over and shut, and a cam should engage the throttle to hold the throttle open a touch.
If it's not flipping shut and holding the throttle open on its own, there may be an issue with the pull-off coil not being adjusted correctly, the choke plate shaft may be bent or the bushings or linkage may have simple dirt interference.
Old 09-09-2012, 01:54 AM
adeantoni's Avatar
also i forgot to add that when i shut the truck off with the key it says running. it doesnt shut off immediately. it delays then shuts off as of today. which i also have no clue which would cause that. im hoping they are related. because they both started at the same time.
Old 09-09-2012, 05:14 AM
Possibly the fuel cut solenoid.
Old 09-09-2012, 10:28 AM
x2. Sounds like that's not shutting properly. But should be completely unrelated to your idle issues. As far as my choke adjustment, it's only a 3 year old carb and the choke is adjusted from the factory. My choke plates move freely by hand.
Old 09-09-2012, 06:06 PM
slow-mo's Avatar
x3
Here's some pictures of the Fuel Cut Solenoid. The first on is where it is located on the carb. The second shows a description of what it controls. The second pic doesn't show the shading very well to denote the fuel passage of the idle circuit.
The Fuel Cut Solenoid blocks the passage way the the fuel would travel to the idle port.
Old 09-10-2012, 04:09 AM
The ONLY thing that fuel cut solenoid control is fuel going into the carb's idle fuel. It does not control the fuel bowl vent, nor does it control the choke. Toyota is not a feeedback carb system.
Old 09-10-2012, 09:22 AM
adeantoni's Avatar
ok ill check it out when i get it back home next weekend. Im off at college, and most of my tools are back home but hopefully soon i can take a look at it... i might just switch over to my weber though.. so i don't have to deal with the toyota carb anymore.. thank you guys for responding. ill be checking out all the ideas as soon as i can and ill report back
Old 09-10-2012, 10:27 AM
slow-mo's Avatar
Correct. It was not my intention to imply that the Fuel Cut Solenoid did those other things. I was just using an already taken picture of mine to show the location of the FCS.
The federal carburetors are not the "feedback" type, but the California models are. Toyota even states that it uses a feedback carburetor in the FSM.
We (California) have the extra functions of the oxygen sensor, the Electronic Bleed Control Valve (EBCV) & the Electronic Air Control Valve (EACV). The last two will alter the air of the air/fuel mixture of the combustion via the emission computer. The EBCV does it upstream of the combustion chamber, in the carburetor, and the EACV does it after the combustion chamber, in the exhaust manifold.
Old 10-16-2012, 11:31 AM
adeantoni's Avatar
I also figured out that the idle issue when the throttle wasnt sticking was caused by the egr valve. it was sticking which caused a vacuum leak. so i disconnected the vacuum lines from the egr and plugged them. now it runs perfect.
Old 10-16-2012, 01:12 PM
kornhuskerwizard's Avatar
if the tank had some junk in it and it was real low it could have possibly picked up some junk on the bottom of the tank. kind of like a sink drain when it gets about empty it takes the junk down last. possibly have it in the carb somewhere now.
just a thought.
Old 10-16-2012, 01:42 PM
adeantoni's Avatar
just a thought.
That's what I had thought happened originally. I went through and cleaned it but that didn't help. Because it was the egr valve.
sandyota
02-04-2021 11:16 AM
Sleaker
08-26-2020 06:03 AM
Alex Bessinger
08-31-2015 09:17 AM
kyletbert
07-17-2015 11:39 AM
cars-guy
07-11-2015 07:51 PM
Quick Reply: Idle issues on my 22R
