idle air control valve o ring?
Old 05-13-2010, 07:44 PM
shafner30's Avatar
hello
i have a 1990 22re 2 wheel drive with a stick shift.
i was told by toyota parts that the idle air control valve does not have a o-ring.......
and i was told by toyota parts that the automatic transmisson.. does have a o-ring ...
i find it hard to beleave that the stick shift does not and the automatic transmisson does please let me know ..
thanks
Old 05-13-2010, 09:07 PM
iamsuperbleeder's Avatar
wait I'm confused
what are we talking about here now, a transmission or an IACV?
I don't think there's an o-ring in it regardless; matter of fact, I think they would be the same IACV no matter the trans
but on an auto trans, the idle is just set higher when in a nuetral gear
if there IS an o-ring in it, I don't think it's servicable
but, I could be proven wrong...
Old 05-13-2010, 09:35 PM
874runnersr5's Avatar
i think he's referring to the screw on the TB with the oring in it... one says trucks with auto dont have the oring and stick ones do..
Old 05-13-2010, 09:57 PM
the idle adjustment screw?
that SHOULD have an o-ring, regardless of the trans, I would assume
Old 05-13-2010, 09:59 PM
bingo.. thats what im thinking
Old 05-13-2010, 10:14 PM
I know my stick shift had one, 'cause I replaced the old hardened up one that was in it, lol
matched it up at a parts store out of a big bin full of o-rings; cost me all of like $0.20
Old 05-14-2010, 06:03 AM
hilandfrog's Avatar
What setting did you start out with on the BBS, Big Brass Screw??
All the way in, then out 3 turns??
Repo
Old 05-14-2010, 06:58 AM
sb5walker's Avatar
I'm pretty sure that shafner30 is talking about the o-ring gasket for the AAV (auxiliary air valve), what you guys are calling the IACV, shown on page EG1-202 of the fsm:
http://personal.utulsa.edu/~nathan-b...34throttle.pdf
It's not unusual for there to be differences in the engine based on things like transmission - the throttle opener, for instance. Also, I think 2WD 22RE trucks lack a knock sensor while 4WD trucks have them.
But I agree, shafner30, that it is unlikely that the AAV on the MT trucks lacks a gasket. I have the 3VZE so can't tell you for sure. Maybe SOMEONE here will let you know...
Old 05-14-2010, 07:07 AM
hilandfrog's Avatar
Are you refering to this "O" ring??
If so I don't believe getting one in a rebuild kit will happen.
Buying one from yota is probably the way to go.
Good luck, I found the IACV to be a real pain.
Repo
Old 05-14-2010, 07:21 AM
shafner30's Avatar
yes i am talking about the o ring on the idle control valve..the one in the pic above this post.
toyota parts say..
if you have a automatic transmission you need the o-ring...
if you have a manual transmission you dont need it...
i find it hard to beleave that..
let me know
Old 05-14-2010, 07:53 AM
hilandfrog's Avatar
I'm just a dumb a**, but that O ring keeps air and cooling fluids from mixing, I'd say it is a must have for either.... DUNNO
Repo
Old 05-14-2010, 09:20 AM
crafthorse's Avatar
I have to agree that there should be that o ring on both models, it does the same function.
Old 05-22-2010, 10:29 AM
gweelie's Avatar
Does anyone know what the iacv looks like on the throttle body off of a 3vz-e engine? I don't have that removable bottom piece.
Old 05-22-2010, 10:34 AM
sb5walker's Avatar
I think it's integral to the throttle body with no serviceable parts. But I'm not sure. Let us know if you find otherwise.
Old 05-22-2010, 10:44 AM
gweelie's Avatar
It has a removable cover that exposes what looks like to be a plundger with ring that could possibly be backed out but I'm waiting to find some more info before I go and screw with stuff I know nothing about.
smthwsn357
05-01-2024 07:28 AM
Charecter1
11-06-2023 10:08 AM
Eggslinger
06-08-2019 03:32 PM
coryc85
09-09-2015 06:24 AM
Alex Bessinger
08-31-2015 09:17 AM
Quick Reply: idle air control valve o ring?
