Identify a replacement part & earn $
Old 07-15-2017, 12:53 PM
  #81
gsp4life's Avatar
Originally Posted by Clifford1990
Cold Start Injector Time Switch....is that a different name for Thermo Time Switch?
When looking around I get the above name more often.
Such as this
With the black one looking very similar to the one I'm looking for
Yep, that black one is what you're looking for. It's referred to as any combo of those terms, we'll call it the CSI thermo-time switch just to be on the safe side, K? It's really expensive as you probably just learned so if I were you, I'd test it to make sure it's really no good. The testing procedure is outlined really well on the 22reperformance.com website. I think it involves heating a pot of water and testing with a multimeter at a cold temp and then hot. Your cold start injector could also be clogged, and is cheaper than the thermo time switch, so be sure before you throw over $100 at it.
Old 08-04-2017, 07:59 AM
  #82
Clifford1990's Avatar
Very vague question...
Does anyone know where this goes?
Also, can someone double check the following codes displayed in this video
https://www.youtube.com/watch?v=TUg0...ature=youtu.be
I have the following codes: 24, 31, 42, 51, and 52
Is this correct?
Old 08-04-2017, 09:31 AM
  #83
gsp4life's Avatar
That looks like the distributor hold-down bolt. That thick washer prevents the distributor from rotating which would change your timing. When you put that bolt in, be sure to use rtv or threadlocker to prevent an oil leak. It's one of 3 bolts on a 22re that require sealant.
Old 08-04-2017, 09:35 AM
  #84
gsp4life's Avatar
I have an earlier ecu than you so I'm not familiar with those codes, but yeah the numbers look right to me.
Old 08-04-2017, 09:53 AM
  #85
gsp4life's Avatar
I took a look at what the codes meant out of curiosity and you either have a handful of bad sensors, or much more likely some faulty wiring. Check each sensor with a multimeter to see if it's getting power. If not, you'll have to trace a wiring diagram, physically locate the wires-in-question and visually check for corrosion, breaks or damaged insulation. Also likely is that the damage all occurred at the same place. What a pain, glad I have an '85!
Old 08-04-2017, 02:18 PM
  #86
I do agree with you on the sensor wiring.
I am familiar with that bolt on the distributor.
Could you tell me the other two locations you mentioned?
Old 08-04-2017, 03:23 PM
  #87
gsp4life's Avatar
The top-most oil pump bolt needs sealant. The other one is the right-most egr bolt where it pipes from the head next to the intake manifold.
Old 02-13-2022, 06:29 AM
  #88
Brapp2Smokin's Avatar
Originally Posted by Minerbob
CSOUT said: Bump for this thread to let you guys know you helped out another yotatech member. Just received and installed the two seals:
90304-76005(MAIN) CV SIDE
90316-60004(SUB) KNUCKLE SIDE
Fit perfect on my '90 SR5. And this says it all...
Hi all, I know this is an old thread with lots of great info but I spend 40 minutes at Napa looking for this knuckle seal using all the PN numbers on here with no luck. I have a 91 4x4 pickup. Does anyone have a link to the knuckle dust seal part instead of a PN? My old rubber seal that came out of the knuckle fits perfectly over my new CV axle, so I don’t think I need anything specially but I can’t find that standard dust seal for the life of me.
The KOYO-CR PN is off the seal I pulled from the knuckle.
Old 02-13-2022, 02:16 PM
  #89
tazmaniac_37752's Avatar
Reply about dust seal.
On the older vehicles those dust seals were not vehicle specific however I believe it may actually be called a axle seal!
QUOTE=Brapp2Smokin;52473764]Hi all, I know this is an old thread with lots of great info but I spend 40 minutes at Napa looking for this knuckle seal using all the PN numbers on here with no luck. I have a 91 4x4 pickup. Does anyone have a link to the knuckle dust seal part instead of a PN? My old rubber seal that came out of the knuckle fits perfectly over my new CV axle, so I don’t think I need anything specially but I can’t find that standard dust seal for the life of me.
[/QUOTE]IQUOT
Old 03-03-2022, 05:35 PM
  #90
Talking
I realized what I was doing wrong and wow is it embarrassing. Hopefully, you guys at least get a good laugh. I tried putting the seal in with the old metal lip still in the knuckle. Enjoy that for what its worth!
The following users liked this post:
millball (03-03-2022)
Old 03-04-2022, 02:46 AM
  #91
Dust seal
The replacement seals can be difficult to install however I had a 55 willy jeep with the same problem and was told to put the blue high temp grease in the knuckle. Took a while to get it in there with a spoon but that was 25 years ago and haven't had any problems. I was told the the high temp grease stayed thick enough to not run out from around the seal but would thin out enough to keep things lubed. If you do this I recommend you fill it up with as much as you can possibly get in it.
jsn_stockard
09-14-2014 08:39 AM
babyfood1217
04-01-2011 03:39 AM
jrdefran
10-06-2006 07:22 PM
ARB4STUNNA
9
07-11-2006 04:06 PM
4RunnerFever
02-14-2005 03:35 PM
Quick Reply: Identify a replacement part & earn $
