I just replaced clutch and flywheel slight whine
Old 02-01-2011, 06:15 PM
4high4low's Avatar
Hey guys new to the site so hope im posting this in the right place.I just put in a new luk clutch kit Pilot,throw out and clutch. when I have the pedal pressed down no noise, fully released no noise, but when starting out from first a slight whine starts once the pedal leaves the floor until it is fully released. Did I do something wrong or could this be new clutch and flywheel wearing in together any help would be much appreciated Thanks in advance!
Old 02-01-2011, 07:33 PM
justin_4runner's Avatar
its hard to really say with out having something to listen to to tell about the noise, make a video of the noise and post it might help us tell u more if its normal.
Old 02-01-2011, 09:57 PM
dntsdad's Avatar
Mine made a slight whine.......just faint enough to be noticeable......for about 2-3 days and then it went away. Everything mechanically has always worked fine. No idea but glad it left.
Old 02-01-2011, 10:04 PM
Pool Playen Bob's Avatar
those luk clutches your supposed to match up with a luk flywheel. idk why. i just know there warranty is voided if you don't. said so on the instruction booklet when i was gonna put on in a ford f-250.
sounds like clutch noise/chatter. but a video/ sound clip would help.
Old 02-02-2011, 12:18 PM
4high4low's Avatar
thanks for your responses
I'm trying to get the video on here I recorded the sound but ya have to listen carefully over engine noise
Old 02-02-2011, 12:34 PM
4high4low's Avatar
well i cant get the video from my phone on here is a slight whining noise while releasing clutch pedal all the way down no noise all the way up no noise just in between guess ill just have to drive her and see if it goes away if not bust out the tools and start over thanks for trying though fellas
Old 02-02-2011, 01:31 PM
snobdds's Avatar
Usually a whineing noise after a clutch means there is grease or oil on the clutch disc itself. I always just take brake cleaner and hose it down and air dry it before I do the final instal.
Old 02-02-2011, 02:48 PM
to get a video on here u will need to email it to your self then put on photobucket or something like that and then load to here, just so u know for the future.
Old 02-06-2011, 02:00 PM
4high4low's Avatar
well i took it back apart clutch looks good, flywheel looks good, throw out bearing spins well and same with the pilot ,maybe it is just the new flywheel and clutch mateing up but I am going to replace the clutch fork and spring for good measure put her back together and see how it goes thanks for the input I will update after install
Old 02-10-2011, 03:36 PM
4high4low's Avatar
Update worn clutch fork was the answer
smthwsn357
05-01-2024 07:28 AM
mskalmus
05-28-2017 07:51 AM
09-04-2015 09:27 AM
Kalihi,HI
07-09-2015 04:29 PM
MTLroadierunner
07-06-2015 12:17 PM
Quick Reply: I just replaced clutch and flywheel slight whine
