I did it Auto to Man Swap. But have a code 42
I did it and love it. The Auto trans to man trans. But I am getting 1 code it 42 speed sensor. Is there anything I can do? Please help if you can. Justin
Location: Yotatech, because Pirate is too expensive. NorCal.
You say its the speed sensor? Is your speedometer working fine? I would guess that the computer is trying to sense speed so that it can shift the auto trans. I bet a computer from a manual trans would fix the problem. But there is probably an easier, cheaper fix. Just need someone with more knowledge to chime in.
I need the model and year first then I can tell you more. Is the speedometer output electrical or cable driven?
Warning, another one of my long tech oriented answers*
*Basics from the Auto Connector out in order to make it run..
2 biggest black wires are the neutral safety switch wires, one's B/W the other's usually B/R.
~Run two wires off of them to your lower clutch pedal sensor switch. These are your starter wires, you want it so you have to push the clutch in fully to start it, but have the circuit open when the clutch is off in case you have cruise control or if no cruise so you don't accidentally start it while in gear.
2 smaller wires, I'll have to look at are for the back-up lights, which aren't a part of your problem..
Here's the Diagram
You did wire in the backups and the brake lights right?
Also, you need the auto controller box from the auto shifter assembly. Take it off the shifter (*unscrew it and unplug the wires), but actually save the plug with the two wires going out of the shifter that are for the overdrive by cutting the two wires free where they lead into the shifter arm.
Whatever plugs are left, plug in. One connector, the bigger female blue with a male white and the other connector both are white. (Refer to my pics below for reference). Note* I pulled off my ECT switch as there's no need for it. On one of the now open connectors, the one with the two small white wires for the O/D select you take the two white wires that are side by side and splice them together. Your "O/D Off" light should now be on, showing the circuit is complete. If there is still a fault it'll flash showing you still need to resolve the transmission communications.
I just finished mine up and after two days of hammering on it, i have gone ahead and pulled the bulb, but am going to go back and actually wire in a small single throw switch. This way if normal driving I don't have a silly light there, but if something acts up with the engine and throws a code I can jumper the diagnostics and see if it threw a transmission code after switching the circuit back on so it'll function the way it's supposed to.
Basically there were 2 computers before and need to be two after, both of which throw codes, keep both diagnostics available. Cool?
Making sense at all?
If not I'll try to monitor the thread.
The speedometer is working its right on with my GPS. .My back lights and brake lights work. So that is all done. I will check the rest of what you said thank you for your time. Justin
Kelley, that is A LOT of great information. I did the auto to manual swap on my 88 3VZE as well and was wondering if you can specify what year your truck is and if you can better tell which colors the wires are.
The BEST would be if you had pictures of all the ways you wired everything up.
The only thing we did was to jump the 2 large wires off the white plug so the truck thinks it is always in Neutral or Park.
Kelley, that is A LOT of great information. I did the auto to manual swap on my 88 3VZE as well and was wondering if you can specify what year your truck is and if you can better tell which colors the wires are. The BEST would be if you had pictures of all the ways you wired everything up. The only thing we did was to jump the 2 large wires off the white plug so the truck thinks it is always in Neutral or Park.
*Hope this all helps..
Last edited by KelleyC; 07-16-2009 at 02:00 PM. Reason: Clarification and Pics Added :)
Is it possible that when the previous owner of my truck swapped out the at for the mt the at computer never got put back in. My truck has numerous problems w/ wiring(no back up lights, no check engine light, no clutch safety switch). I have a bundle of wires jumpered and taped up hanging under the throttle body. I don't even know where to start.
Find the computer for the automatic transmission and unplug it and remove it, because its no longer needed. That should stop the code. You don`t need to change the engine computer. The computer for the transmission is totally seperate from the engine computer.
Bump..I recently got a message asking for the tech on how the wiring was completed on my build. I just felt it the right thing to do here by sharing the info on just who figured it all out (keeping the cruise control intact and resolving the issue of fuel mix affecting the smog #'s)..Shane's the one who did the work with us and we used his info here to do it all: http://www.toyota120.com/forum/showthread.php?t=20939 I no longer work with him but I found him to be a really nice guy who's got some skills when it comes to vehicles and always willing to help us out. If anyone else searches the wiring question my answer above is the basics he gave me, but ultimately you might want to talk to him for oddball stuff.
Shane, although you're not on this forum (banned IIRC) and you might not get to see this post I just wanted to have people know you were the one who helped us out and I appreciated it, as does the person who sent me the message and got to figure it out from your info.
*I know you and Corey get along fine now online (Expo) and I hope this is Ok to have posted.
Awesome stuff, thanks Kelley (and Shane!).
This swap is likely in my near future, as my slushbox is starting to lose reverse. This thread and the one you linked will help immensely!
I recently completed this swap, and have to say it was pretty easy and well worth the performance gain.
My major issue now is a code 42. I have studied the wire schematics, my ECT is hooked up, O/D is off, speedo cable hooked up and i jumpered the Neutral on the ECT so the truck thinks its in Park/Neutral. I did this because i was getting engine stumble at shift points (2500-3000 rpm) and i read that a solution is make the ECT think it is in Park/Neutral. I got the code 42 before i jumped the neutral, and can remove it .
Before the swap i had no codes, but now i can get the code 42 just by revving the engine, actually id i hold it at 2500rpm. And when it stumbles the fuel/air mix goes crazy and eventually settles down.
Anyone know why i am getting this error?
thank you
thank you
pita
Sorry to rez a dead post, its snowing like mad here and im at a loss.. swaped my 1990 4 runner 3vze to 5 speed did not wire my rev lights figured id do it later on. as soon as snow fell I try and put it in 4wd nd nothing, you can hear 4low whinning like normal but still spins out. guess its wiring? another post from skinner talks about having to wire the rev lights (2 wires) and 4wd (2wires) in order to work. got my rev lights going and tryed this 4wd one as my plug are the same color etc as his in his post, still no 4wd. jumped the wires from the pins he refered to 2&3 on blue 6 pin plug and still no 4wd. I guess jumping the wires is suppose to trick the system to think the tcase is in 4wd? any help on wiring or a diagnosis would be greatly appreciated.
Thanks.
Thanks.
I assume you have ADD; did you hook it up?
http://personal.utulsa.edu/~nathan-b...26addcontr.pdf
06-01-2021 01:51 PM
nframe
3.4 Swaps
08-16-2015 09:03 AM
