Hydraulic Throw Out Bearing
Old 01-30-2009, 09:18 AM
T-1000's Avatar
Thumbs down Hydraulic Throw Out Bearing
I think the R series of transmissions use a clutch fork, is there anywhere I can get a hydraulic throw out bearing for an R series transmission?
I'm planning on mating an A series bellhousing to an R series transmission and I'm pretty sure it'd be too difficult to make a mount for a clutch fork...
I need some advice on this. Thanks in advance.
Old 01-30-2009, 06:15 PM
Pistonman's Avatar
If you mean a hydraulically actuated clutch, IE a master and slave,Toyota is set up that way. If you mean hydraulic throwout bearing, check into circle track parts.
Old 01-31-2009, 07:32 AM
[N8]'s Avatar
http://store.summitracing.com/partde...5&autoview=sku
If you do some searching there is a Jeep model that has an AISIN manual tranny and it's throwout bearing setup will work too.
Old 02-01-2009, 09:11 PM
T-1000's Avatar
I'm pretty sure it's the AX-15.
Thanks for the tip.
Longbed 90
03-11-2019 12:38 PM
Ronnyboy
02-11-2016 05:57 PM
YotaPagota
09-20-2015 06:24 PM
93toyoguy
3.4 Swaps
10
09-18-2015 04:16 PM
justdifferentials
09-05-2015 06:52 PM
Quick Reply: Hydraulic Throw Out Bearing
