How to remove washer nozzle 86 22R Base pickup
Old 07-03-2022, 04:29 PM
ivgotit's Avatar
Question How to remove washer nozzle 86 22R Base pickup
Does anyone know how to remove these nozzles? I have tried needle nose and screwdriver ... no go. Thanks!
underside of washer nozzle 86 22r pickup
washer nozzle 86 base pickup 22r
Old 07-04-2022, 09:33 AM
JoeS's Avatar
Looks like a ring of 6 spring prongs that all have to be compressed at the same time. Try a mini tie wrap to hold all the prongs in. You may have to hold it over the prongs as you push up. Maybe electrical tape around them just at the end so the top retaining section can passes through the hole.
Just a guess.
Old 07-04-2022, 02:03 PM
slacker's Avatar
they are difficult ! but can be done . there is a groove on the sprayer those "tangs" fit into , you need to move all of them out at the same time to pop it out .
I have them in stock if you need
The following users liked this post:
JoeS (07-04-2022)
Old 07-04-2022, 02:56 PM
ivgotit's Avatar
Thank you Joe! I will let you know if I break one. Otherwise I plan to clean and reinstall them. Kent
JoeS (07-04-2022)
BurnNFabSkrt
All Other Toyota Swaps
01-28-2022 10:18 AM
Upsidedown86
11-19-2020 10:07 AM
DolinFMX
03-23-2014 01:01 PM
jburress10@yahoo.com
11-11-2013 11:56 AM
Quick Reply: How to remove washer nozzle 86 22R Base pickup
