How many Sensors are on a 4runner, can you name them
Old 10-06-2008, 06:19 PM
simpsons721's Avatar
Talking How many Sensors are on a 4runner, can you name them
How many Sensors are on a 4runner, can anyone name some
i want to know beacause ive had problems with my runner and need to know what sensors are working
thanks
Old 10-06-2008, 06:21 PM
Jay351's Avatar
Here are some common(ish) sensors/parts that you should check:
AFM
O2 sensor
TPS
Coolant temp sensor
Also, check for vacuum leaks...
Old 10-06-2008, 06:24 PM
abecedarian's Avatar
umm...
throttle position sensor
air flow meter
intake air temp sensor
coolant temperature sensor
cold start time switch
distributor / hall effect
knock sensor
EGR temp
O2 (could have 1 or 2)
Neutral safety (clutch) / park / neutral
what did I miss?
Old 10-08-2008, 04:51 AM
Skinsfan6's Avatar
How bout that damn sensor that makes that high pitched sound when the driver's door is open with the key in the ignition...
Old 10-08-2008, 07:38 AM
Cyberman's Avatar
Engine Control Input Signals
Water Temp
Intake Air Temp (AFM)
Oxygen Sensor
RPM Signal (Crankshaft position)
Throttle Signal (TPS)
Vehicle Speed
A/C Switch
Battery Signal
Intake Air Volume (AFM)
Stop Light Switch
Starter Signal
Engine Knock
4WD Signal
There are obviously others for transmission (gear selector, transfer case, etc.), braking (brake fluid level), oil pressure, parking brake switch, etc.
Old 10-08-2008, 07:47 AM
ozziesironmanoffroad's Avatar
too many sensors what happened to the days when there was ONE or TWO sensors? where you jumped in the back of your buddys truck and went cruisin, where you checked your idle speed with the door hanging open?
Old 10-08-2008, 10:22 AM
just a 22re's Avatar
oh man the door open trick i hane not heard that one i a long time now a days you cant do that anymore tomany things to go wrong
and everyone forgot the stupid one that i only have lol the temp one ontop of the t-stat housing and yes noone ive talked to has this lol what does it do i have no idea
Old 10-08-2008, 10:30 AM
96redtoy's Avatar
sandyota
02-04-2021 11:16 AM
smiley52
07-11-2015 05:16 AM
nick b
07-11-2015 04:38 AM
Huntingtruckcletus
07-08-2015 05:26 PM
wilbertd
07-06-2015 07:39 AM
Quick Reply: How many Sensors are on a 4runner, can you name them
