How far can the 3.0 go?
Old 04-09-2007, 12:19 PM
  #41
windhamjk's Avatar
Originally Posted by Stomis
Going to hit 170,000 this weekend. It had the heads reworked and a new gasket about 50,000 miles ago (not out of my pocket). When it frys I plan to drop a 2.3L vortec chevy.
If you're planning on buying a crate 2.3 you might be suprised to find you can get a Vortec 350 for not much more. I have a 96 Chevy p/u with the Vortec 4.3 and I went to the dealer to inquire about a crate 4.3 to replace mine when it goes, and I found out the 350 is actually less money.
Old 04-09-2007, 01:54 PM
  #42
Brad.'s Avatar
Mine has 121,000 miles on it and it runs pretty good Im getting 18-19 MPG right now. Head Gasket replaced in October 1998.
Old 04-09-2007, 02:03 PM
  #43
intense's Avatar
Originally Posted by 91_4x4runner
240K on my 3.0. Has a valve tick, an oil leak, and is exceptionally underpowered, but it moves me from point A to B going to the redline every shift, so I'm not complaining.
Wow, yours an mine must be related, except mine has 265K.
Previous owner did the belts and WP at 240K. Beyond that, I have no idea what's been done
  #44
prior185's Avatar
my 90 runner has 450 000km on origainal head gasket. it is leaking a little oil but runs great. would like to rebuild or repower the runner
Old 04-09-2007, 02:04 PM
  #45
BamaT4R's Avatar
Stock 3.slow on 180k, never had the HG problem
Old 04-09-2007, 02:49 PM
  #46
Dan_in_WI's Avatar
197,000 on my 92 4RUNNER.
I called Toyota and found the HG recall was done at 81K in 1998.
The timing belt cover has magic marker written on it saying the timing belt was also changed at 81K. If it was replaced after I don't know. So it is on my list of things to do. 116K on the timing belt seams a bit much since the recommended interval is 60K.
Old 04-09-2007, 03:25 PM
  #47
jay33's Avatar
my 89 4runner has 224,000 on the original head gasket
Old 04-09-2007, 03:36 PM
  #48
LTrunner's Avatar
89 runner with 194,xxx on it, original HG,runnin full synthetic oil....runs like a champ no porblems at all
Old 04-09-2007, 05:16 PM
  #49
92sr5yota's Avatar
I bought the truck in october with 78xxx and now have around 88k, runs like a champ and beat on it pretty hard...air born more then once...
Old 04-10-2007, 07:20 AM
  #50
elripster's Avatar
My 89 had 297,000 miles on it when it was stolen. It ran great requiring no oil between fill ups. It had the heads done in the high 180,000's. I had the 5 speed, 33's, and 4.88's.
My current truck, a '94 has 140,000 on it, it's an auto with 4.88's. The heads have been done. We'll see how she holds up.
Frank
Old 04-24-2007, 07:52 PM
  #51
nerdlip's Avatar
I had the headgaskets replaced under the recall at about 64,000 miles. The replacement headgaskets just let go this week at 201,500 miles. That's not too bad i guess since nothing major was damaged that the stealership could see. Seems to run fine now.
Old 04-24-2007, 08:47 PM
  #52
Blurr's Avatar
about 135k on my 93 3.0. head gasket blew two weeks ago so it is sitting and begging me to decide to drop serious coin to have it fixed or to attempt it myself.
Old 04-25-2007, 01:51 PM
  #53
cbrsport17's Avatar
62137 miles on my 1990 3.0 4Runner, still the original engine too...guess its still got a ways to go looking at all the high numbers that other people have
Old 04-25-2007, 05:43 PM
  #54
kpaxfaq's Avatar
165,000 on my 95' runner 3.0, had the headgasket done at 158,000, it's been good since
Old 05-21-2007, 04:11 PM
  #55
toywagen's Avatar
i got 205,000 and my head gasket just blew! last week..other than that no problems..
Old 05-21-2007, 04:14 PM
  #56
toywagen's Avatar
i got 205,000 on my 91 runner and my head gasket just blew! last week..other than that no problems..
Old 05-21-2007, 05:56 PM
  #57
Bumpin' Yota's Avatar
278,000 here!
Old 05-21-2007, 09:06 PM
  #58
2WDoffroadx's Avatar
my 2.4l has got 197k. New alt. Perfect upkeep, should outlast any 3.0
Old 05-21-2007, 11:48 PM
  #59
amusement's Avatar
140K when I sold it. No head gasket problems.
Old 05-22-2007, 05:11 AM
  #60
Mark in MD's Avatar
Originally Posted by Toddski
I will hit 254,000 this week on my '91.
Only thing that has been done it the water pump and timing belt. Still getting 18 mpg
Wow! No blown head gaskets? That's amazing. Anything you can attribute that to, besides good luck?
Quick Reply: How far can the 3.0 go?
