How to break in a newly rebuilt 3vze
Old 05-11-2013, 12:12 PM
cheappc's Avatar
How do you properly break in a 3vze?
Old 05-11-2013, 04:57 PM
MudHippy's Avatar
I swear buy this.
Old 05-11-2013, 07:57 PM
cheappc's Avatar
Originally Posted by MudHippy
I swear buy this.
What an incredible write up? is this for reals? So break it in hard to 65mph at short intervals? AND COMPLETELY WARM UP THE ENGINE..
and change the oil AFTER ONLY 20 MILES... wow... will do that!!!
Old 05-12-2013, 12:48 AM
wyoming9's Avatar
Red face
If this has new cams this would be after the cams are run in.
When the engine is first started.
Old 05-12-2013, 05:59 AM
MudHippy's Avatar
These aren't flat tappet cams were talking about. They're essentially rollers cams. As in there's a "bearing" that "rolls" when the cam lobes come into contact with the tappets. That "bearing" being the clearance adjustment shim, which rotates as the tappet is pushed on by the cam lobe.
Bottom line: There's no break-in period for these cams. This isn't a 22R-E.
Old 05-13-2013, 11:40 AM
WestSideVB's Avatar
I recently purchased a to be installed complete engine and was asked to follow this procedure by Denny's Auto Machine.
This engine has been tested for “Ring Seal” and prepped with Break in Oil. This oil MUST be removed at or before 300 miles.
Proper Break In Includes:
  1. Quick Start Up. Avoid over fueling and improper timing.
  2. 10-15 minutes of fast idle at 1500 RPMs.
  3. Drive immediately, load engine at different speeds and RPMs not to exceed 3,000 RPMs or 50 MPH for 15-20 minutes.
  4. Normal driving for 300 miles. Avoid constant speeds (Interstate driving).
  5. Drain Break in oil, and replace with HD oil of your choice. No additives or semi or full synthetic oil until your engine has 10,000 miles on it.
This jives with my limited prior understanding of engine break in. No constant speeds, a variety of speeds, Don't drop the hammer or lean on it to hard, a specific start up procedure, and special oil the first bit. Look good to you fellas?
Old 05-13-2013, 03:35 PM
MudHippy's Avatar
Not too bad.
I like pretty much everything except the "No additives or semi or full synthetic oil until your engine has 10,000 miles on it." part. I don't see why not after the post-300 mile break-in oil drain. IT'S ≥99% BROKEN-IN AT THAT POINT!!! IF you did it right...
As far as, "don't drop the hammer or lean on it to hard", strike that. Reverse it. That's what is meant by "load engine at different speeds and RPMs not to exceed 3,000 RPMs or 50 MPH". Which is a rather vague way of putting it. What that all really means is lots of WOT(Wide Open Throttle) and NOT(Not Open Throttle) driving, at rpm up to atleast 3000 rpm(but not much more) and/or 50 mph(but not much more). For atleast 15-20 minutes(but not much more). Then normal drive atleast ~300 miles(but not much more) before break-in oil drain. See also the previously posted link.
That's what I recommend.
SubiKing
08-21-2021 03:57 AM
calderp
Engine Swaps
08-16-2016 05:15 PM
anniesball
07-29-2015 11:46 AM
calderp
07-27-2015 09:58 AM
tomczaksdiesel
07-26-2015 10:35 PM
Quick Reply: How to break in a newly rebuilt 3vze
