Horrible Gas Mileage...WHY?!
Old 10-11-2013, 08:24 AM
  #41
KtrainHurricane's Avatar
Originally Posted by Gamefreakgc
I hate being the bearer of bad news, but I too was under this assumption with my tires and found out otherwise.
If you have an SR5, they came with 31" tires, much like the Taco's after them. Not all models, but the SR5's did. I currently have 225/75 R15's, what the "books" say the truck should have. Here's my discovery: https://www.yotatech.com/forums/f116...nfused-272221/
Basically, if you drop lower than 31's your tires are spinning more per mile and giving a false reading. Your MPH's and MPG's are inflated by 9%. For example, a recent road trip was 91 miles, and my odometer read 100 by the end. GPS says 63 MPG, speedometer reads 70. Use a smartphone or GPS that reads MPH and you'll see what I mean.
My truck came with 235/75R15, not 225s, so would this slight difference still be the cause of an increase of over (what I assume is going to be) ~50 or more miles per tank?
Also, I have a double-din radio with navigation, and use it often. According to it, I am going exactly what my speedometer says; when I had the 235s from my old steel wheels, it always read +2 MPH faster. I always found that odd since 235s were the stock tire size my truck came with...
Old 10-11-2013, 09:37 AM
  #42
Gamefreakgc's Avatar
You might be ok then. Your truck might have had the gear ratios changed or the speedo changed to accomodate the larger/smaller tires (or maybe yours was actually set up for 225/75 R15s). That 2 MPH different is what I mean, so it seems like your truck is geared for the exact size you have.
So in your case, it was flipped. The old tires you had were giving a false reading in the opposite, you were actually going more miles and getting better gas mileage than you thought!
justdifferentials
14
06-11-2017 08:36 PM
sanctfy
09-13-2015 06:33 PM
Tcsdef
09-07-2015 11:17 PM
Wardog
09-06-2015 07:57 AM
raptor510
08-19-2015 02:15 PM
Quick Reply: Horrible Gas Mileage...WHY?!
