HILUX SURF ln130 2.4 litre turbo diesel part number thread
didnt see too much when searching here.. i think YOTA TECH needs more toyota diesel love.
here is a list of the part numbers i have collected.. during my 3 years of toyota diesel ownership.. i like to use OEM toyota parts and like to keep filters on hand.
NGK GLOW PLUGS
y-188t-1
these numbers now are all OEM TOYOTA NUMBERS
RIGHT HAND DRIVE IDLER ARM
45490‑39375
Timing belt
13568-59066
Timing idler #1
13505-54021
Timing idler #2
13503-54030
Water pump
16100-59257
Crank oil seal
90311-42026
Cam oil seal
90311-32018
OIL FILTER
90915-30002
Alternator Belt uses double belt on alternator and waterpump
90916‑02209
newer number 90916-02211
Power steer/Vane pump belt
99332-00830
A/C belt
99332-01260 or 99332-01265
Air Filter - 17801-54060
Fuel Filter - 23303-64010
NGK GLOW PLUGS
y-188t-1
45490‑39375
Timing belt
13568-59066
Timing idler #1
13505-54021
Timing idler #2
13503-54030
Water pump
16100-59257
Crank oil seal
90311-42026
Cam oil seal
90311-32018
OIL FILTER
90915-30002
90916‑02209
99332-00830
A/C belt
oops forgot these parts are for ln130 hilux surf 2.4 litre turbo diesel engine...
toyota canada had a 2.4 non turbo till 1986 so some parts i can get local some parts i have to order.
that pipe is crazy expensive slacker.. i dont know if you still need it as its years ago but i used a pipe that my mechanic uses to exhaust outside it has worked for a year... but my friend is going to thailand next week and going to ship me some parts so if you need let me know!
Diesel love!
Happy to see some more righties out there. I'm working for the money to dump into my Hilux Surf. It might be parked a while longer but I'm going to do my research while I try to be patient.
while I got ya .. is the battery on the Left hand side on the surfs ?
Power steering??
NGK GLOW PLUGS
y-188t-1
45490‑39375
Timing belt
13568-59066
Timing idler #1
13505-54021
Timing idler #2
13503-54030
Water pump
16100-59257
Crank oil seal
90311-42026
Cam oil seal
90311-32018
OIL FILTER
90915-30002
90916‑02209
99332-00830
A/C belt
NGK GLOW PLUGS
y-188t-1
45490‑39375
Timing belt
13568-59066
Timing idler #1
13505-54021
Timing idler #2
13503-54030
Water pump
16100-59257
Crank oil seal
90311-42026
Cam oil seal
90311-32018
OIL FILTER
90915-30002
90916‑02209
99332-00830
A/C belt
the part number for the power steering? Where do I go to buy these parts??
FS[SouthEast]: Mercury Villager Fan & DCC Fan Controller
coryc85
09-09-2015 06:24 AM
