High Mileage Yotas!
#81
I sold this 93 22re with 471,234 miles! On the original clutch. All I ever did to it was weld a little hole on the downpipe and I did the timing chain and a battery. The day I sold it the compression was as good as the day it rolled off the boat!
#82
Location: Where it always works if you work it, in Sunny Selinsgrove, PA
this is semi irrelavent, but I just rolled 210k miles on my 97, and she still doesn't use oil! I ran synthetic for 5500 miles and none was missing... I am impressed.
#83
take any pics of the odo? thats pretty crazy haha. We had one for sale locally about 3 or so years ago with 415,000 miles on all original parts, in good running order! It said high mileage in the ad, I figured like 200k max, and I called and found out it had that many haha.
#86
Does the motor at least have to be in the rig first? I mean, waiting on an LCE order shouldn't count, should it?
Either way, hope you get it up and running soon.
Oh yeah, 87 4Runner 22re 5 speed. 187,000. Still factory, although could use an overhaul. the gaskets leak oil, pretty sure its not being burned.
1988 single cab short box 2wd 22r 4 speed. only 130,000 on original motor. It'll never die. 27 mpg, too.
#87
my buddy had a 1987 4runner that had 383,XXX miles on it and it looked like brand new he bought it from the original owner in December we put clear turn and park lights on it stripped the interior and cleaned it and reassembled and put a timing chain in it. it didn't have a spot of rust on it. unbelievable
#89
i have 320,*** ill post a pic tomorow. still runs strong. i thank the motor has been rebuilt. with mods because i have 33's tires with stock gears and i pull them great.
#91
176,xxx on my red 94. my neighbor has a yota that he bought brand new in 94 that has about 300,xxx. you should see the loads of firewood he STILL hauls in this thing, the bed is sheetmetal w/ steel frame. replaced fuel pump last year. it is amazing what these trucks can do. also his drive to work consists of over twenty miles of back roads...
#92
When I picked up my runner, it had 233,XXX kms on it. I just round it and say 150k miles. I've only had it about a month, but I plan on owning it for a long time.
#95
96 Tacoma... 227,000 miles (Clutch and an ignitor)
87 Extracab 4x4 278,000 (P.O said he did a headgasket on it years ago)
86 Std cab 4x4 255,000 (Rebuilt at 200,000k when it dropped a valve, crappy rebuild, still runs but barely)
#97
406xxx km. its not on original engine though. original went to about 326000 km the PO put a new crate engine in or somthing. so i have around 80k km on my new engine running strong. 22re btw and the rest of the truck is all stock( tranny, rearend and susp)
