High mileage and with a turbo
Old 12-23-2010, 04:34 PM
Tweasl's Avatar
I think its possible especially with a turbo.
Larry
Attached Thumbnails High mileage and with a turbo-dscf0835a.jpg   High mileage and with a turbo-dscf0837a.jpg   High mileage and with a turbo-dscf0842a.jpg
Old 12-23-2010, 04:48 PM
yotarover's Avatar
holy cow thats high
Old 12-23-2010, 04:58 PM
Tweasl's Avatar
She needs bit of inspiration with a 3vzfe and possibly a turbo
Old 12-23-2010, 07:01 PM
rattlewagon's Avatar
Where are you getting the turbo from?
Old 12-24-2010, 06:32 AM
Tweasl's Avatar
I work for Borg Warner Turbo so I'll probably source one from there.
I will need to first run the numbers on the engine such as displacement, anticipated HP, airflow etc and see what I come up with. Do you have any recommendations?
Old 12-24-2010, 08:16 AM
93YotaGuy's Avatar
I'd be interested to see this take place. Keep me posted!
Old 12-24-2010, 08:24 AM
Tweasl's Avatar
As I get stuff figured out I'll post it. I welcome the advice from others too.
Old 12-24-2010, 08:28 AM
93YotaGuy's Avatar
Just so we are on the same page, do you plan on adding a turbo to your 3vz-fe?
Old 12-24-2010, 01:41 PM
Tweasl's Avatar
That would be the idea
Old 12-24-2010, 03:39 PM
camo31_10.50's Avatar
i don't believe the 3VZ-FE will mount into the pickup honestly
Old 12-24-2010, 04:21 PM
Tweasl's Avatar
The engine mount to the tranny is the same as the 3VZE. I should be able to swap oil pans from the 3VZE to the 3VZFE. I will use the rubber motor mounts from the 3.0 and build some plate steel blocks to mount on the 3VZFE and then fab these to the rubber mounts which will bolt to the original truck frame mounts. This will be the easy part.
Old 12-24-2010, 04:24 PM
WJC
WJC's Avatar
I'd be interested if it's possible ... increased mileage and (I assume) power?
Old 12-24-2010, 05:20 PM
Tweasl's Avatar
Mild turbo with Mega Squirt tune should be an easy 300 HP. A challenge for sure but I have a lot of good help...
Old 12-24-2010, 05:27 PM
not the typical project for the average toyota Do-It-yourself mechanic.
a great project for sure!
it'd be nice to have the dual overhead cam design for my 3vz
Old 12-24-2010, 06:09 PM
Tweasl's Avatar
Its like a huge jigsaw puzzle. Start with the easy stuff and continue till the puzzles all filled in......Ha we'll see.
Old 3VZE block is being steam cleaned and mag checked at the machine shop along with the oil pan, windage tray and oil pick up. When I get these I'll bolt up oil pan get engine in truck and work on the mounts. 3VZE will get rebuilt for my other truck.
Old 12-24-2010, 06:16 PM
aa1911's Avatar
what level of boost are you thinkin'??? 5-10psi?? I think this would be a fun project, and something to bragg about to all us peons, hahaha!
boost it!! hahaha....
Old 12-24-2010, 06:30 PM
Tweasl's Avatar
10 psi would be nice. I might even go so far as build the engine to be turbo specific. Lower the compression and at least clean up the heads bit. This way I wont have to worry about controlling huge timing issues with a higher compression engine. I still want to run cheap gas. A friend of mine who is a Mega Squirt nut suggested we do two timing maps, one for go and one for mileage. My truck has two fuel tanks in it so I could even use different fuels......but that's for another day, after its all working.
Old 12-24-2010, 09:02 PM
MudHippy's Avatar
Talked to Toysrme about this yet? I'm sure he has some pointers.
Old 12-25-2010, 05:10 PM
93YotaGuy's Avatar
Sounds fun! Yay can't wait for updates!
Old 12-26-2010, 09:38 AM
Tweasl's Avatar
I'll post things as they go. One step at a time and we'll see where it leads.
Thanks for the inspiration
Quick Reply: High mileage and with a turbo
