Help me find Overdrive Solenoid..please?
Old 05-15-2006, 01:37 PM
Comfortably_Dumb's Avatar
Question Help me find Overdrive Solenoid..please?
Hello,
I have a 1986 2wd truck with the 22R automatic transmission, and I am wanting to find the solenoid that allows the transmission to go into overdrive. I have already tried to locate it using autozone.com but no help there.
Also, any OTHER suggestions you may have would be greatly appreciated, as my problem is. ...will not shift into overdrive. The overdrive on/off light works but it will not go into overdrive.
Thanks a bunch for any help you can give me.
Old 05-15-2006, 01:39 PM
I meant to put a comma between 22R and Automatic, I meant 22R...AND automatic transmission, the way I wrote it looks like Im trying to say 22R transmission..
Old 05-16-2006, 09:16 AM
anyone? please
Old 05-16-2006, 12:45 PM
regularguy412's Avatar
Look here for more info:
http://personal.utulsa.edu/~nathan-buchanan/93fsm/
You first need to identify which transmission you have.
MIke in AR
Old 05-16-2006, 07:31 PM
Hi, Thanks for answering.
Honestly I dont know what transmission it has, when we bought it the transmission had been changed from one on the column to one on the floor, but it still has the overdrive button, and when you push the button the light does go on, then push again, it goes off.
If you know how to tell me what transmission it is, I would be extremely grateful, as I have googled and googled the info I have to no avail.
Here is what it says on the transmission (if I am reading it right)
Stamped on the transmission casing it says: 8961
Stamped on the transmission ID Tag it says: Series: 84kf 03208
it also says Borg Warner and what LOOKS to me like 13 AW
Thanks again for your help
Old 05-16-2006, 08:05 PM
I'm gonna guess and say that it's an A340F auto tranny. If you use the link I previously posted and go to the 'Automatic Transmission' section, you can choose A340F and scroll thru to see a schematic of the location of the solenoids.
Mike in AR
The following users liked this post:
JoeS (06-24-2022)
Old 05-17-2006, 04:31 AM
Thank you for your help, I printed the link you provided and hope I can figure out my problem. The link you gave looks to have some helpful stuff.
Thanks again.
Old 05-17-2006, 04:03 PM
It's the 1993 Factory Service Manual for pick-up trucks, but it will work for most issues pertaining to 1988-1995 Pick-ups and 4Runners.
Mike in AR
Old 05-20-2006, 10:37 AM
StoogeBrother's Avatar
Probably a bad o/d switch o your gearshifter. Check the dealer for pricing.
Old 05-20-2006, 08:56 PM
toyotaoffroad91's Avatar
check the coolant temp sensor also is it controls overdrive pull codes and see if the o/d light blinks the solenoid is in the valve body closest to the bellhousing resistanse shoud be 11-15 ohms
Old 10-02-2015, 07:14 AM
Phillip Soltan's Avatar
Overdrive Bypass
I have an '87 Toyota pickup that had a broken overdrive solenoid. Since I couldn't find a new thermostat to allow the overdrive to turn on it didn't make sense to buy a new solenoid.
What I did was take the solenoid apart, take out the wires, spring and plunger and epoxy it back together. Now the overdrive is ALWAYS on and it seems to work find.
Old 06-24-2022, 12:19 PM
Paws84pickup's Avatar
I have an 84 Toyota that won;t shift into overdrive. It would occasionally shift previously but not now. Where is the solenoid that controls this located and can I just bypass it as you suggested?
Thanks!
Old 10-10-2022, 05:18 PM
dereka6's Avatar
Most of the 85 thru 90 Toyota 4 cylinder trucks have the same transmission as the Volvo 240 has.. I installed the overdrive solenoid from the Volvo and it works just fine on my ** pickup
JoeS (10-11-2022)
Old 10-11-2022, 07:21 AM
JoeS's Avatar
https://parts.toyota.com/p/Toyota_19...542021090.html
Liadrin
04-25-2022 02:54 PM
polo451
13
11-20-2016 07:49 PM
Liadrin
09-01-2015 06:44 AM
keithporter83
07-24-2015 07:37 AM
HookahRoo
07-20-2015 07:06 PM
Quick Reply: Help me find Overdrive Solenoid..please?
