heating problem - 89 4runner
Old 11-15-2010, 07:09 PM
KNou's Avatar
my heater isnt that hot. it's warm but not as hot as i think it should be. does anyone know some things to check out?
thanks for your help!
Old 11-15-2010, 07:36 PM
Motox711's Avatar
I have the same problem with my 87 4runner. i haven't had the time to go through everything. some things i have checked first to make sure the heater lever is hooked up. the easy way is in your engine compartment on the firewall where the heater core lines go in there is a valve. this brings hot antifreeze into the heater core. if the valve is plugged or not working this will be one problem. but if you have someone move the heater switch in the truck and it moves in the engine compartment. then my guess the heater core probably has a plug or something. there's my two cents..
Old 11-16-2010, 07:01 AM
swampfox's Avatar
Try feeling the heater hoses at fire wall ,the one going in to the heater core and the one coming should both be hot at operating temp. If they are it could be the fins of the heater core plugged with debris and it needs blown out . If one hose is a lot warmer than the other that could indicate a plugged core internally or the valve not working right as Motox said.
Old 11-16-2010, 07:08 AM
waskillywabbit's Avatar
Flush your coolant system with the heater loop open. It's gunked up probably.
:wabbit2:
Old 11-18-2010, 04:26 PM
KNou's Avatar
thanks fellas!
bigjstang
08-25-2021 12:41 AM
Jnkml
07-06-2015 01:20 PM
karbin
07-05-2015 11:37 PM
HRDC0R19
07-05-2015 06:43 PM
Quick Reply: heating problem - 89 4runner
