Headgasket 101 and discussion 22R/22RE
Old 09-01-2012, 09:15 PM
  #121
kanyonkritter's Avatar
its an easy mistake to do....yes you need a new gasket
Old 09-01-2012, 09:16 PM
  #122
if they have already been torqued that is
Old 09-04-2012, 05:51 AM
  #123
fissure333's Avatar
Hey MudHippy-
"PS, your avatar...looks like that one road up on Goat Mt.. I've got pics of my truck parked in the snow in that exact same spot, if I've nailed that as squarely on the head as I think I have."
-well you're close. it's up squaw up near fanton trail head. not too far past the "Y" if ya know where i mean.
Old 09-21-2012, 06:45 PM
  #124
freedyv200's Avatar
kinda off topic, bt are head spacers any good?
Old 11-03-2012, 09:23 AM
  #125
kornhuskerwizard's Avatar
nice thread, put in my two cents... i have 8k on rebuild that i did. i used engnbldr gasket kit, timing chain, cover, new head bolts, tensioner and rails. I tourqued according to the fsm BUT... i already had the timing cover on the engine and tourqued, which could have something to do with the oil leak at the front of the head and timing cover. other than that its ok, however on my 4runner build i plan on using oe head gasket even though im a cheap sob. i still plan on using engnbldr parts otherwise beacause theyre price is right for me. if i had the cash damn right id go factory parts but id never get anywhere cause i cant afford it. as far as reusing head bolts i was always told to replace with new ones which is how ive done. i also agree clean and dry on the head gasket and some oil on threads of head bolts prior to assembly. im by far not as experienced as some of you guys with 22r 22re engines, but i love the simplicity of them and theyre reliabilty. I will own these rigs for as long as i live or they live. ill take a toyota over a jeep any day of the week!!!!
Old 05-05-2015, 09:53 AM
  #126
ditypup's Avatar
I have around 2K on my rebuild now, I used Hastings nodular iron rings and a Beck/Arnley factory type Made In Japan head gasket that I got from a local Toyota service shop. I have no leaks and it is not using oil. I torqued all the bolts in the engine according to the factory specs. It runs very well. I am crossing my fingers that the oil consumption issue doesn't happen. Also I used King bearings made in Israel.
Old 05-07-2015, 10:18 AM
  #127
BK2TFUTURE's Avatar
My kit only lasted 11k before things got serious. Had to redo everything since I had a trifecta of leaks.
This time I went with 22reperformance which included the OEM head gasket in their kit. On top of that I am now using ARP head bolts which require 90lbs of torque. Unfortunately I used the same head bolts for the first rebuild and I do not recommend that cork oil pan gasket that comes with a lot of kits out there.
I pray I will not have a head, timing cover and/or oil pan leak again!
Old 05-07-2015, 03:27 PM
  #128
Odin's Avatar
Are you talking about the stud Kit #: 203-4201 http://arpinstructions.com/instructions/203-4201.pdf
90lbs Wow, I wouldn't have thought the torque would be that much different from stock.
Old 05-07-2015, 04:02 PM
  #129
BK2TFUTURE's Avatar
Same here!!! I was surprised as well when I saw that number.
They are the experts though
Old 05-07-2015, 04:09 PM
  #130
Odin's Avatar
I haven't read this to the end so I don't know the outcome, but it's something to think about
22RE ARP head studs causing oil starvation?
http://www.pirate4x4.com/forum/toyot...-4runnKit%20#: 203-4201er/516102-22re-arp-head-studs-causing-oil-starvation.html
Old 05-07-2015, 04:26 PM
  #131
BK2TFUTURE's Avatar
Hmmmm, I just did an 900 mile round trip over the weekend.
Well, Yotatech will be the first to know if something go BOOM.
Old 05-15-2016, 10:12 AM
  #132
ditypup's Avatar
I have approximately 4800 miles now on my rebuild. Had to replace the oil pan gasket with FIPG and replace the oil pump gasket. Other than that it is running well and it is not using or burning oil.
TheBFA
02-15-2020 06:55 AM
alimant100
01-20-2016 05:58 PM
_Nicco_
09-21-2015 03:06 PM
carid
Vendor Advertising
09-10-2015 06:11 AM
defrag4
07-31-2015 10:50 AM
Quick Reply: Headgasket 101 and discussion 22R/22RE
