Hazard/turn signals dead...
Old 08-31-2012, 04:35 PM
93toyota4x4's Avatar
They were working just fine. Last weekend I tore the dash out to change my heater core. I just got around to putting it back together tonight and my signals don't work.
When I searched the issue I found a bunch of posts saying they could hear the flasher clicking but no lights where working. With mine, everything is dead. No lights, no noises, nothing.
I have checked all the fuses, the horn works, I swapped the hazard switch with one that I know works. I was Just wondering if anyone knew of something simple that I overlooked. I guess tomorrow I will be pulling the dash back off and chasing wires...
Old 08-31-2012, 04:42 PM
James Woods's Avatar
Sounds like something didn't get plugged back in or got torn.
Old 08-31-2012, 04:49 PM
Yeah, I was sure I plugged everything back in except for the plugs for the air conditioning (which I don't think have anything to do with the signals). I will have to pull the dash and double check. I really hope it isn't a broken wire.
Old 09-01-2012, 06:16 AM
Found out that the plug on the cross bar under the steering wheel is the flasher (I wondered if that was it from the start). When I was taking things apart it was hard to pull the plug apart, now I'm wondering if something broke in the flasher.
Old 09-01-2012, 06:35 AM
Problem solved. Went out and looked at the flasher, one of the prongs was bent and was going in beside the plug. Took a screwdriver and bent the prong back and opened the plug a little wider and everything works fine.
kawazx636
10-06-2021 03:03 PM
justdifferentials
14
06-11-2017 08:36 PM
calderp
11-16-2015 02:49 AM
Scotttekoch
09-28-2015 10:30 PM
Boomer8404
09-24-2015 01:12 PM
Quick Reply: Hazard/turn signals dead...
