Hard shifter
Old 07-06-2012, 08:29 AM
pieps57's Avatar
Hard shifter
1988 toyota 4 cyl w 5 spd manual tranny...over the past few weeks it has gotten harder to shift thru all the gears. I replaced the fluid w synthetic and no change.....any ideas on what it could be?
Thanks
Old 07-06-2012, 09:24 AM
waskillywabbit's Avatar
Elaborate.
:wabbit2:
arlindsay1992's Avatar
Check that the clutch pedal bracket isn't cracked. It's a common problem with these trucks. It prevents the clutch from dissengaging completely.
Old 07-06-2012, 09:27 AM
Here's a thread with some more details and fixes on that problem. When you say you replaced the fluid, do you mean transmission gear oil, or clutch fluid? Is the system properly bled? How many miles on the transmission? I had one with 320,000 miles and it made a hell of an awful noise in second and third, but it shifted like butter.
https://www.yotatech.com/forums/f116...fatigue-32667/
Old 07-06-2012, 10:58 AM
skjos's Avatar
Don't forget the shifter seat bushing. Some yotatech searches should bring up additional information. You can order it from here:
http://www.marlincrawler.com/transmi...ver-ball-seats
DP4Runner's Avatar
shifter seat
I changed out my shifter seats. It shifts so much better now.
Both of the stock ones were completly broken up into very small pieces most of which i think fell down into the transmission in my 94.
Old 07-06-2012, 11:01 AM
My trans with 320,000 had no shifter seat or shift bushing left. Had lots of play but, like I said earlier, shifted like butter.
Old 07-06-2012, 12:38 PM
pieps57's Avatar
Sorry I wasnt more specific....The clutch has about 3000 miles on it. I replaced the transmission fluid with synthetic fluid. The old tranny fluid looked ok. The clutch fluid is at normal level....
The hard shifting started about 3 weeks ago. It is hard to shift from gear to gear while your driving, you really have to jam it in. It is also hard to get into reverse, even at a complete stop.
Thanks
Old 07-06-2012, 12:47 PM
myyota's Avatar
As said above, check the shifter seat and the little plastic bushing on the end of the shifter. That should go a long way to fixing your problem.
Old 07-06-2012, 12:59 PM
TrikeKid's Avatar
Check to make sure the clutch line and slave aren't leaking, and that the mc isn't leaking out the back (yeah yeah, the fluid is at the proper level, just trust me and check em). What's the clutch pedal free-play like. Shifter seat will make it harder to find gears, which can make it harder to grab them as well (end up trying to snag more than 1 gear at once and get nothing). I would agree with replacing it simply because I've never gone to replace one in these trucks and actually had to remove the stocker, they're usually just flat out gone.
Is it hard to get into 1st/reverse as well? I really think you have a clutch issue somewhere if it's in every gear, all the time.
Old 07-06-2012, 01:36 PM
Bleed the brakes. Make sure the hydraulic system is working properly. And make sure the pedal bracket isn't cracked.
Old 07-06-2012, 01:58 PM
pieps57's Avatar
Bleed the brakes?
I will order the shifter seat bearings..where is the tag on the tranny located so I can find out which tanny I have?
I will also look over the whole hydraulic clutch system
Old 07-06-2012, 02:06 PM
pieps57's Avatar
Checked the clutch pedal bracket....no cracks or damage
Old 07-06-2012, 02:11 PM
Sorry. Obviously I meant bleed the clutch.
Old 07-06-2012, 02:13 PM
pieps57's Avatar
Ok thanks!
Old 08-21-2012, 05:11 AM
pieps57's Avatar
Turned out to be the master cylinder...after further inspection it was leaking a lil on the inside of the vehicle where the pushrod enters it...replaced it and she shifts like a dream
Thanks
yoterr
09-15-2015 06:26 AM
reallynotamechanic
09-11-2015 11:52 AM
Boomer8404
09-10-2015 09:01 AM
anndel
09-10-2015 08:50 AM
eggens
09-05-2015 12:16 AM
Quick Reply: Hard shifter
