Grille swap?
Old 04-06-2008, 07:00 PM
tumor21's Avatar
Grille swap?
Does anyone know if a 4x4 style grille and headlight housings from a 89+ pickup will fit directly on a 87? It looks like they would be a direct swap and the only thing that wouldn't be interchangable are the outer hazzards. My grille's chrome a bit worn out and I thought this might be a cool swap for the 86+ trucks.
Old 04-06-2008, 07:33 PM
norcalsvx's Avatar
i have a 86 runner here and a old 94 grille i can try to mount up for ya
Old 04-06-2008, 07:35 PM
Dare44's Avatar
i would guess that the newer ones are taller but it could fit, just a guess.
Old 04-06-2008, 08:49 PM
Staff
DeathCougar's Avatar
Without modification, you cannot simply bolt them on. Sometimes you see it done to show trucks, but they have to alter their entire core support.
Old 04-08-2008, 11:53 AM
4x4phil's Avatar
I have both rigs, I just bought a new grill for my 90, it is a lot wider/taller then the 84-88 style ones.
Old 04-08-2008, 01:24 PM
aviator's Avatar
No sadly the 84-88 and 89-92 and 93-95 grills are completely different and not interchangeable. The 89-92 & 93-95 are similar but the hood line is slightly different and they are both larger in every dimension then the 84-88s which also had some style differences over the years but are completely interchangeable with other 84-88 grill styles.
Old 04-08-2008, 03:56 PM
Yota82's Avatar
Here is my buddy Chris' truck . It is an 86 with a 94 grille ziptied on, looks great nothing custom had to be done.
http://www.cardomain.com/ride/2202274
Old 04-08-2008, 03:59 PM
Flash319's Avatar
Ya you can zip tie them in. I did it to my 88. Put a 92 in it.
Old 04-08-2008, 05:04 PM
aviator's Avatar
I guess you could zip tie one in after all... not sure how secure it would be though...
Old 04-08-2008, 05:11 PM
Luvmeye22re's Avatar
Seems kind of funky to try to upgrade your truck to make it look better and finish it off with zip ties
Old 04-08-2008, 05:13 PM
just a 22re's Avatar
oh man you guys SUCK!!!! you did this to your trucks?????? and didnt even bother calling me???? thanks alot guys now i have to go out and do this to!!!!!
The following users liked this post:
Steeler808 (11-22-2021)
Old 04-08-2008, 06:08 PM
Yota82's Avatar
More secure than the stock little plastic thingys.
The holes don't line up so you have to improvise. It looks fine and you really can't see the zipties.
Old 04-08-2008, 06:15 PM
GenXr's Avatar
Bingo! - - - If you want it done properly.
Old 04-08-2008, 07:48 PM
Staff
I disagree, the stock plastic grill clips hold the grille in very tight and doesn't allow it to bounch around.
Zip ties are not only hokie (sp?) and cheap, they are a poor way to attach the grill. Do it right the first time, rather than having to do it again 15 times. Besides that, it looks terrible when you open the hood or get close enough to see it sticking out like a sore thumb.
Old 04-08-2008, 07:59 PM
BAZ
BAZ's Avatar
I think your buddy's truck looks pretty slick. Does he also have a 3rd gen hood?
Old 04-09-2008, 06:36 AM
Flash319's Avatar
There is no way to do it right because the clips don't line up. Zip ties are fine and much easier to remove if you have to take it off. The plastic clips break then what do you do? Zip tie it.
Old 04-09-2008, 02:16 PM
4x4phil's Avatar
I have put on a custom Dual round head light setup on mine, zip tied the grille to the truck and used black zip ties and u couldn't even tell that there are zip ties on there.
And it holds it on very strong, never any issues.
Old 04-09-2008, 04:40 PM
BAZ
BAZ's Avatar
Dual round headlights? Sounds interesting. Any pics?
Old 04-09-2008, 05:14 PM
Switchtr3's Avatar
yota 82 ill second that, those little plastic things suck! i think theres still 2 left on my grill haha
they work well as designed but they break so easily
Old 04-09-2008, 05:30 PM
Noltz's Avatar
Mine broke too... never bothered to go to the dealer and get more: They'll break also. Zip ties, black, trimmed, look just fine.
MMA_Alex
25
04-18-2017 05:07 AM
lledwod
08-30-2016 01:03 PM
RobotMoose
Diesel Swaps
08-02-2015 11:00 PM
PureTacoma_Tundra
PureTacoma_Tundra
07-23-2015 11:20 AM
jackiebrownia
07-20-2015 09:02 AM
Quick Reply: Grille swap?
