Get in... Turn key... Nothing... Then suddenly it starts... Wierd?
Old 06-04-2013, 04:34 PM
shawnphoto's Avatar
Hey guys, ran into a little problem with the yota yesterday. I got in and turned the key, and nothing happened. Just silence. All the electronics, lights and guages are working fine, but nothing happened except a slight buzzing sound. Then i turned the key again, and it started up fine. Once its hot, it starts fine, and this problem has only started as recently as yesterday. Any guesses on what to check? Starting with cleaning the battery contacts and checking the voltage, but has this ever happened to someone?
Old 06-04-2013, 04:50 PM
brianh699's Avatar
It would help if you included model, year, engine.
Old 06-04-2013, 06:20 PM
Scrussanation's Avatar
sounds like ignition switch (correct me if I'm wrong toyo experts) but mine did same thing, luckily people who had it before me h ad a switch set up for when it does that, like a bypass to the solonoid to get the starter to engage when key was in run position, here lately though the push button switch needed you to hold it in the "sweet spot" and got quite annoying, I replaced with a rocker switch and starts up flawlessly everytime!
Old 06-04-2013, 06:52 PM
XtraSlow_XtraCab's Avatar
You aren't pushing in the clutch far enough, or the switch for it is going out.
Old 06-05-2013, 01:12 PM
blacktail hunter's Avatar
Check your ground too. Follow the negative battery cable from the battery to the other end. It should be clean and tight. Might need to replace your battery cables also.
Old 06-05-2013, 02:31 PM
derockus's Avatar
My guess was clutch switch too.
Old 06-05-2013, 03:07 PM
https://www.yotatech.com/forums/f116...k-3vze-187741/
this is a link to alot of useful information for mine, if you notice it begins on top starting about the starter contacts, mine was a relay issue but maybe it'll point you in right direction. I'm no pro at all this but definately not a noob either
Old 06-05-2013, 05:58 PM
this should help pin point your problem without having to guess.. guaranteed
http://www.4crawler.com/4x4/CheapTri...shtml#EasyTest
1992pickupSr5
05-09-2019 08:44 AM
JHalcyonM
08-04-2015 01:19 PM
pyramid
07-30-2015 10:05 AM
PlayAwhile
07-20-2015 11:36 AM
Quick Reply: Get in... Turn key... Nothing... Then suddenly it starts... Wierd?
