Gen1 4 Runner slider window L trim
Old 08-06-2007, 05:30 AM
ewong's Avatar
I know that Corey/Slacker makes fiberglass ones
http://www.toyotafiberglass.com/IM001424.JPG
$150cdn for the PAIR
I have seen OEM ones around for sale
Last one I saw was $100 a side
I also have heard that there are TWO different screw types (a 6 screw and a 7 screw configuration?)
I was THINKING about getting a pair of L trim panels made up in stainless steel by subcontracting the job to a sheet metal place that makes Industrial Kitchen Counter tops and stuff.
Such as:
http://www.sheetmetal-usa.com/stainl...-stamping.html
What I'm wondering is target price...
$200 for the pair?
Old 08-06-2007, 07:40 AM
89macrunner's Avatar
I called up yota yard and had them send me a pair that were in decent shape..
I primed and painted them...they were $50 shipped for both sides i think
Old 08-06-2007, 07:45 AM
ewong's Avatar
Thanks - so $200 is over priced (for you anyway)
Old 08-06-2007, 07:59 AM
Just at tip...when you are reintsalling the window use urethane to put them back in..its MUCH better than butyl.
IF you want to use butyl make sure that all of the old stuff is cleaned off and the surface is clean before you reinstall the window..they CAN fall out (don't ask me how i know) Goof off works well for this job
Old 08-07-2007, 07:35 AM
Greg_Canada's Avatar
6 or 7 doesnt matter, there is just one extra screw across hte bottom for some, doesnt effect anything.
Just get corey's fiberglass ones, you'll be happy.
Old 01-31-2016, 08:51 PM
808_4runner's Avatar
Exclamation Metal L Trim
Hey guys!
just landed my self a new metal L trim for the back seat window driver side ( current one has a golf ball sized rust hole in it.
i thought that all i had to do was take off some panels on the inside and unscrew it from the rear.
alas thats not the case. i was hoping that some one might have a step by step way of doing this?
thanks again. this forum has always been a good help!
Old 01-31-2016, 11:28 PM
Staff
Terrys87's Avatar
You have to remove the complete glass assembly and once it is off, you will have access to the screws.
L Trim Removal.
To get the L trims off, you have to remove the whole window from the inside. On Passneger Side, I have my feet in the floorboard and knees in the seat, I place my left arm across the top and apply pressure from my elbow to my fist. Applying a little more with my elbow and start breaking the glue tht holds the window in. I try to keep all of the glue on the glass portion. I use a putty knife to help. Once I get the top seperated from the cap. I hook my arm thru the window to keep it from falling to the ground. Once the glass is out, the L trims are just bolted to the window part which will be visble when out.
Old 02-01-2016, 05:50 AM
thefreqofnature's Avatar
I'm looking for a pair of these myself. This is great info! Thanks guys!!
Old 02-01-2016, 07:00 AM
Terry thanks for the pictorial instruction! next hot day on the weekend putty knife in hand ill hack at it! i was on ebay looking for a shifter bushing rebuild kit and going through the listings the L trim was there. i had to jump on it. I'm surprised what i can still find for my faithful blue 4 runner. just rebuilt the engine too. she's a 220k and she's ready for another 200k
06-01-2021 01:51 PM
lledwod
08-30-2016 01:03 PM
Jnkml
07-06-2015 01:20 PM
toyoda8488
07-05-2015 10:18 PM
HRDC0R19
07-05-2015 06:43 PM
Quick Reply: Gen1 4 Runner slider window L trim
