gasket or sealer? Thermostat housing neck
Old 04-14-2013, 07:10 PM
DeadPhish's Avatar
Do you know if the thermostat housing area has a gasket or if the one that wraps around the actual thermostat is the only one needed. Its a 3vze 95 4runner 4wd. The kit came with the new oring type gasket that wraps the thermostat but I was wondering if the actual housing needed something.
Old 04-14-2013, 07:17 PM
DeadPhish's Avatar
this is where i am talking about
Old 04-14-2013, 08:42 PM
YotaWoRx's Avatar
Rubber fitted gasket is all u should need....
Old 04-14-2013, 09:29 PM
hunter4runner's Avatar
Rubber gasket is best choice
Old 04-14-2013, 11:24 PM
brianh699's Avatar
FSM doesn't call for anything but rubber gasket http://personal.utulsa.edu/~nathan-b...10thermost.pdf
Old 04-15-2013, 08:39 AM
DeadPhish's Avatar
I will have to pull it and make sure I have the Jiggle Valve on the top, thanks for that link.
The ring/seal that came with the rebuild kit didn't fit like the original. It was larger in diameter so I reused the old one. It looked to be in pretty good condition and if it leaks it is pretty easy to get to and replace.
the1998sr5
15
07-14-2020 08:35 PM
Flossy
08-05-2015 05:14 PM
horunner1x
07-10-2015 06:33 AM
Edionne13
07-09-2015 01:59 PM
Quick Reply: gasket or sealer? Thermostat housing neck
