gap guard help
Old 03-17-2008, 12:22 AM
joshuapc's Avatar
gap guard help
i bout my 90 pick up with a three inch body lift. im interested if any one has any recommendations on making my own or should i just buy the gap guards that Parts Accessories sells for around eighty dollars? thanks!
Old 03-17-2008, 12:36 AM
ovrrdrive's Avatar
What is gap guard?
Old 03-17-2008, 01:04 AM
Elton's Avatar
like so
Old 03-17-2008, 02:34 AM
ovrrdrive's Avatar
That's what i was guessing...
People actually pay for that?
Seems like if you wanted it they wouldn't be that hard to make out of thick plastic (plastic slip sheets for pallets would be perfect) or even sheet metal for that matter. The gaps never really bothered me...
Old 03-17-2008, 06:50 AM
Robert m's Avatar
lawn edge molding from home depot/lowes works good too
Old 03-17-2008, 10:35 AM
joshuapc's Avatar
really? ive had friends make um out of tar paper but that stuff rips easy. i guess ill have to just experiment and look around
Old 03-17-2008, 10:38 AM
joshuapc's Avatar
hey OVRRDRIVE..i noticed that it says you have bj spacers with a 4'' superlift. i was wondering how the spacers affect your lift, cv angle, and how does it perform with the lift?
Old 03-17-2008, 10:42 AM
AZ4ME's Avatar
Pond liner is the best. Pick it up at Home Depot or Lowe's where they have the little pond tubs you can install.
Old 03-17-2008, 01:24 PM
joshuapc's Avatar
Any one got any pics of there gap guards?
Old 03-18-2008, 01:03 AM
ovrrdrive's Avatar
Everything aligned perfectly according to the computerized alignment I got. As a matter of fact the alignment tech was impressed that I used them for some reason. He saw them as soon as he looked at the front end.
The truck rides great.
Old 03-18-2008, 11:11 AM
joshuapc's Avatar
thanks for the info! so you said you had to align it yourself? hows the cv angle?
Old 03-18-2008, 12:15 PM
racingcameron66's Avatar
where did you get um i cant find them any where
Old 03-18-2008, 01:26 PM
ovrrdrive's Avatar
I did a rough alignment in the driveway then drove it to the shop. CV angle is no worse than it would be if you did a mild tbar crank.
The BJ spacers?
I got mine from TRDparts4you or whatever. It's Toyota of Dallas. Just order the ones listed for the 89-95 4runer. It's the same part. They're the cheapest place around.
Old 03-19-2008, 09:42 AM
BRreddog's Avatar
I made mine out of some rubber conveyor belting material. I traced the outline of the stock one and added a few inches for my 2" body lift. Bolted 'em on with stainless hardware.
Old 03-19-2008, 05:15 PM
joshuapc's Avatar
sounds good. i just needed some ideas on what type of material i should use. i might use inner tube rubber but it might be hard to work with and might not look nice.
Old 12-11-2009, 09:15 PM
BlackTacoTRD's Avatar
Hey i have the gap guards from performance accessories and i was wondering if anybody could help me figure out how to install the rear ones. Thanks
smilen724
13
11-08-2015 04:11 PM
themightykhoner
09-18-2015 02:28 AM
BimmerSage
09-17-2015 11:48 PM
Corvoid
09-14-2015 10:10 AM
anniesball
09-07-2015 11:20 AM
Quick Reply: gap guard help
