Fuel & temp gauge not working!
When I pulled the fuel sender out of the tank, it was very obvious that the rust on the wire windings which the slider moves along was inhibiting metal to metal contact, hence the gauge would drop out totally until the level in the tank dropped or raised past the rusty spot.
It tried removing the oxidation, but the wires are so small/fragile that they broke loose. So what I did was remove the section of wire that was oxidized and then gently twist the remaining sections together at the ends and then apply a bit of solder to keep them intact.
This in effect gives you continuous gauge readings, but the fuel sender is no longer linear in terms of reporting the fuel tank levels. Not really an issue for me since I keep a full tank as often as possible.
Hope this helps.
Hope this helps.
My gas gauge wasn't working for the longest time. Swapping gas tanks, clusters, better grounds, and everything i could think of. Then i followed the wiring harness a bit and noticed it was hanging and got smashed and a couple wires were exposed. Fixed them and works fine. Pretty obscure though...
looks like I have a fun project then. I am picking up my second toyota ever today and one of the issues it has is at half a tank of gas, the gauge drops to empty. Works great from full to half though. The truck is an 86 22R 4x4 5Sp.
#27
No float, like the one on page 35? http://web.archive.org/web/201102052.../6combinat.pdf I can't imagine that the fuel gauge would register at all without a float.
Could you have knocked the float off the arm when you changed the pump?
#28
I’m having similar issues with the temp gage and fuel gage on my 1983 Toyota pickup, was driving back from work and they both stopped working. about 10 minutes before I noticed they quit working they were both on point and working properly. I have no idea how to fix this issue and any help would be awsome!
#29
the1998sr5
10-19-2016 12:48 PM
Avenged
07-09-2015 07:55 AM
B. Graves
07-03-2015 04:10 AM
