Fuel Pump Wiring Harness
Old 04-11-2011, 06:02 AM
Brazos's Avatar
I have a 1993 4wd pickup 22RE & manual transmission. The fuel pump stopped working so I took the bed off and got the pump out of the fuel tank. It turns out the pump works fine but one of the wires that plugs into the connector that plugs into the pump was burnt up at the point of connection. I was able to scounge up another connector and resolder and get the truck running again. That being said I would like to replace the pump and the little wiring harness that goes inside the fuel tank and powers up the pump. Does anyone know where I can get another wiring harness with the correct plug (that plugs into the pump) attached? Stupid me forgot to take pictures or right down part numbers before putting everything back together.
Old 04-12-2011, 07:00 PM
Brazos's Avatar
Anyone have an idea? Figured I would bump this back up for another day.
Old 04-12-2011, 07:10 PM
Baggedgmc1995's Avatar
Have you tried talking to the Toyota dealer parts guys? They should be able to give you a parts diagram for the fuel pump. You will need the harness end and pins that go in it.
Old 10-01-2016, 08:33 PM
LAtoyotafan's Avatar
Me too
I had the exact same problem. Changed the fuel pump then 2 weeks later no fuel pump again. Broken terminal in the fuel pump harness in tank. Finding a new harness the correct length didn't happen. Had to add an inch to a new harness that came with pump from auto parts store.
Old 10-01-2016, 08:52 PM
muddpigg's Avatar
I replaced fuel pump bracket and it came with harness attached.
Old 10-02-2016, 03:01 AM
wyoming9's Avatar
That comes with the fuel pump bracket
You might be able to still order the connector not sure if you can get the pins from Toyota
Your best option is to get a male and female water tight plug and install that .
If your in the liquid brine area that stuff gets in every where.
smthwsn357
05-01-2024 07:28 AM
Charecter1
11-06-2023 10:08 AM
TURBOrunnerNM
07-22-2015 11:01 AM
redneck17
07-17-2015 07:44 PM
Huntingtruckcletus
07-08-2015 05:26 PM
Quick Reply: Fuel Pump Wiring Harness
