Fuel Pump/Sending Unit help
Old 09-30-2011, 06:58 AM
ChickenFriedMX's Avatar
Getting ready to change out my fuel pump. Does anybody have any tips? Just ordered pump and strainer from rockauto.com. I am having trouble finding the sending unit. Anybody got a link for me? yeah my truck was just driving down the road and it quit on me. Not sure what the problem is but the fuel pump has been acting sketish. and the fuel gauge dont work anymore so I figured I would do them both. Any tips would be appreciated.
Old 09-30-2011, 07:09 AM
93toyrunner2's Avatar
Year? Model? Motor?
Old 09-30-2011, 07:19 AM
Jkelley429's Avatar
the sending unit/pump hanger is a bitch to find. i had to order mine from the dealer vs. pulling a 22 yr old part out of a junkyard(especially fuel related). i would replace all fuel filters while youre at it. If its a 22re the fuel filter is right above the starter on the passenger side, you will need to take the passenger tire off to get to it.
Old 09-30-2011, 06:42 PM
Yeah Sorry 87 4runner dlx 22re, planning on doing the filter too. I thought I found the sending unit on here one day. just cant find it again. Thanks again for the help.
Old 10-01-2011, 03:35 AM
TNRabbit's Avatar
Is it OEM Denso? If not, I wouldn't bother with it....
Old 10-01-2011, 05:32 AM
Hadmatt54's Avatar
Here are the part #'s for an regular cab 87 dlx 22re 5 spd manual
23206A BRACKET, FUEL PUMP
23206-35121 22REC, 22RTEC..RN66 1 $124.03
23206B GASKET, FUEL PUMP BRACKET
77169-14010 22REC, 22RTEC..RN5*, 6*, 7* 1 $5.73
23217A FILTER, FUEL PUMP
23217-35040 22REC, 22RTEC..RN5*, 6*, 7* 1 $25.82
23220P PUMP ASSY, FUEL
23220-16190 22REC, 22RTEC..RN5*, 6*, 7* 1 $336.26
23229 CLIP(FOR FUEL PUMP FILTER)
23229-16010 22REC, 22RTEC..RN5*, 6*, 75, DENSO 1 $1.03
This is the fuel gauge sender assembly.
83320 GAGE ASSY, FUEL SENDER
83320-39705 RN66..DLX, SR5, SRT 1 $168.78
83361 GASKET, FUEL SENDER GAGE
83361-20030 LN5*, 6*, RN5*, 6*, 7*, VZN6* 1 $3.04
If it is an auto extended cab it lists another part # for the pickup assemlly (bracket)
23206-35120 22REC, 22RTEC..RN66 (08/1985 - 07/1986) 1 $124.38
23206-35121 22REC, 22RTEC..RN66 (08/1986 - 07/1988) 1 $124.03
if you want to be sure of the part # go to http://www.toyodiy.com/parts/
and input your VIN #.
You will find the pickup assembly,fuel pump strainer, etc. under Engine/Fuel Fuel-Injection section 22-11 page 2
You will find the fuel sender under Electrical Switch & Relay section 84-01 page 4 or 5 (the last page of this section)
Blamalam
03-12-2022 07:34 AM
Doug4320
03-24-2018 10:11 PM
mussy01
12-13-2016 08:20 PM
gary4runner
09-24-2015 12:53 AM
Tyler Cunningham
07-11-2015 10:18 AM
Quick Reply: Fuel Pump/Sending Unit help
