fuel pump replacement
Im going to replace my fuel pump tomorow and i was wondering if there is anything i should be careful about and how hard is it to do it?
And do you have to drop the gas tank?
1992 toyota v6 3.0
1992 toyota v6 3.0
On the Pickups the tank needs to be dropped, or the bed removed. Make sure you have a good set of flare wrenches. Rusty tank mount bolts might hold you up a bit. They are in a convenient place to drill out if need be. Just drill it out, replace with any bolt and nut.
Jnkml
07-06-2015 01:20 PM
