Fuel gauge failing
Old 10-05-2014, 02:44 PM
  #41
Teuf's Avatar
My solution. This was about 20k miles ago.
Old 10-08-2014, 05:48 PM
  #42
skeeter0288's Avatar
mine did the same thing. sender gone bad. got universal sender and gauge from moeller marine through amazon for under $50. looking close to$200 for replacement yota sender. gauge fluctuated quite a bit after turning, but at least running down the highway I know how much is in the tank or if it sits for a while as this has historic tags on it, I do not have to worry about remembering how far I have gone so as to put fuel in it.
Old 10-10-2014, 05:29 PM
  #43
halowarmor's Avatar
Scope103 that site seamed to work out for me. I called the place and talked with the guy today. He took my vin number and gave me the propper part number to order so I just placed my order today, and will let you know if this worked out.
Old 11-01-2014, 12:36 AM
  #44
Targheeandme's Avatar
'97 4runner Gas Gauge Issue Fix
Had gas gauge issues with my 1997 4Runner, and finally figured it out. I've searched all the different Toyota sites and read about all the different issues. Mine read full just fine, but got to 3/4 and then would drop to half. Here's the long and short of it. Apparently when this vehicle was new, the dealer installed fog/driving lights. Last week driving home in the dark, I kicked on the driving light switch. There she goes again, gauge dropping, dropping. Then I switched the driving lights off. Gas gauge returned to where it should have been. I couldn't believe it! I had finally solved the mystery. I have dropped the tank & replaced the sender, and then replaced meter cluster, and neither solved the issue. The dealer went from the driving light switch to draw the 12V directly from the battery and, of course, then to the lights. I installed a Hella wiring harness. The switch gets it's 12V from the high beam lead, then goes to the relay, then the lights, etc. The harness and relay solved the issue. Hope this helps for some still dealing with the issue. Don't know why the gauge would be affected by the 12V coming directly to the switch from the battery, but it was my problem. Gauge holds steady now when the driving lights are switched on with the relay & harness.
gary4runner
09-24-2015 12:53 AM
shisha1999
09-21-2015 08:22 PM
Nickyodaman
07-27-2015 12:13 AM
Tyler Cunningham
07-11-2015 10:18 AM
Poncho0206
07-10-2015 06:21 PM
Quick Reply: Fuel gauge failing
