Front Steering Knuckle...where can a fella get one??
Old 06-28-2012, 06:03 PM
pieps57's Avatar
I am looking for a front right steering knuckle(spindle?) for an 88 toyota truck 4wd (the thing that the hub assembly sits on and the cv axle goes thru).....I cant seem to find the exact one I need online and the dealership here is not the greatest to deal with.....I would like to purchase a new one so I want to make sure I order the right one because I am assuming it will be around $200.00
Thanks
Old 06-28-2012, 07:57 PM
drew303's Avatar
look on Craig's list for people selling them.. when we solid axle swap this stuff is junk and sells cheap... used is fine don't waste your $ at the dealership...
what's wrong with what u got? balljoints are replaceable as well as the brass bushings inside
Old 06-28-2012, 11:00 PM
wyoming9's Avatar
Wink
:jessica: If you have your VIN the dealer should be able to get the correct part number.
They very well just might be to lazy I must say my Toyota Parts people are great
I just as soon go with new stuff myself used is ok if your stuck or have a nest full of little ones.
Old 06-29-2012, 08:15 AM
TrikeKid's Avatar
No reason to buy things like knuckles new when there are thousands on the used market. They don't go bad unless they're crash damaged or bad mechanic damaged
terminator
07-27-2015 07:13 PM
yoterr
07-24-2015 04:29 AM
whereAreMyPants
07-22-2015 03:32 AM
voiddweller
07-15-2015 03:56 PM
Quick Reply: Front Steering Knuckle...where can a fella get one??
