front and rear IFS?
Old 07-11-2006, 02:22 PM
F0RSAKEN's Avatar
Originally Posted by LOCKnGO
Thats pretty cool. I like the brake setup
That looks....expensive.
Old 07-11-2006, 04:52 PM
kyle_22r's Avatar
the only reason i'd put IRS on a truck is if it was a street-only rig set up for racing, or an extreme dune jumper. other than that, there isn't really any point.
Old 07-12-2006, 06:45 AM
mastacox's Avatar
Petersen's 4Wheel & Off-Road joked about putting a Jaguar rear-end in a 4x4 for a dune-runner, it has a full-size Dana-44 center section, in-board brakes, that might be what's in this pic, I do see the inboard brakes anyhoo...
Old 07-12-2006, 04:18 PM
kyle_22r's Avatar
i don't like the idea of inboard brakes. on a standard setupl, the only thing that can cause the brakes to not work is either a brake failure(duh) or the hub coming out. on that, if you pop a u-joint or the shaft fails, you have no brakes at all.
Old 07-12-2006, 07:09 PM
  #25
AH64ID's Avatar
True.... they are also more open to mud and gunk, but I would presume they have some benefit since expensive rigs like Jag run them. I know that on the hummer they provide better breaking due to the additonal gear reduction at the hub, so the brake has more effectiveness at lower speeds.
XtraCab
04-12-2020 05:25 AM
lledwod
08-30-2016 01:03 PM
jerusry
10-19-2015 05:28 PM
Daneums
08-20-2015 05:36 AM
toyoda8488
07-05-2015 10:18 PM
Quick Reply: front and rear IFS?
