Fooling your 02 sensor
Old 01-03-2008, 05:41 AM
nate V's Avatar
I thought I might have read it somewhere in this forum but I cant seem to find it. Has anyone out there ever fooled an 02 sensor with a resistor or something similar.
I have successfully done the trick with the EGR valve sensor so I think that it must be doable to the 02's as well.
Just wondering if it can be done thanks ahead for your input.
Old 01-03-2008, 07:45 AM
Flash319's Avatar
If you run a 2 wire sensor instead of the 4 you can put a resistor on the heater lines and this will get your light out. Other then that you can't because the sensor generates a voltage. You can rig up a pot and give it 0-1volt range.
Old 01-03-2008, 07:52 AM
mt_goat's Avatar
Yes, if you're talking about a rear O2 sensor.
Here's what I'm using:
http://www.urdusa.com/product_info.p..._id=1230100014
I have a friend that built his own using these instructions for a guide:
http://www.vfaq.com/mods/O2bypass.html
Both are working on trucks with a 3.4 swap.
Old 01-03-2008, 08:02 AM
to4menon4u's Avatar
i dont mean to hijack but i wonder if this can be done to the knock sensor as well to get my truck out of limp mode
Old 01-03-2008, 03:07 PM
nate V's Avatar
good info thanks goat
to4menon4u i dont know but i assume that it is doable
Old 01-03-2008, 03:22 PM
Elvota's Avatar
Thanks again Mt Goat.
I may try the "build your own" technique as I keep having a code pop up for the rear O2 sensor. I think it's due to my high flow cat or possibly using the wrong sensor (from a '90).
Either way... would be nice to see the light go away.
Old 01-03-2008, 03:31 PM
elvis's Avatar
You and me both; brother... Hikack in progress... See my post on code 12..
(Now returning you to your scheduled posts...)
moparbay
03-10-2023 03:50 PM
jb451
7
10-07-2022 06:58 AM
Kreedy1
09-08-2015 06:33 PM
zz_denis
09-06-2015 03:43 PM
moparbay
09-03-2015 12:48 PM
Quick Reply: Fooling your 02 sensor
