Flooding
Old 02-21-2010, 11:15 AM
langzaiguy's Avatar
Flooding
I have an 89 3.0 Runner that has trouble starting. If I try to start it without giving it gas, it will turn over and immediately die by flooding--I took two front spark plugs out and were doused with fuel. If I press the gas pedal as soon as it turns over, it starts fine. Anybody have an idea?
Old 02-21-2010, 12:22 PM
swampfox's Avatar
if it runs alright after you start it or only floods part of the time,it might be a bad temp sending unit for the ecu. the ecu over fuels the motor thinking it is colder than it really is. it might also be a bad fuel regulator.
Old 02-21-2010, 01:41 PM
langzaiguy's Avatar
Thanks for the reply! As I understand things, that temp sensor is on the back of the 3.0. Would you happen to know where specifically?
Old 02-22-2010, 03:13 PM
swampfox's Avatar
sorry I'm not to familiar with the 3.0,But one of the other members can most likely help you locate it.
Old 02-22-2010, 04:16 PM
94svt50's Avatar
Maybe its a spark issue? Stops sparking but keeps pumping gas for a seacond, making it look like its flooded? Just a thought.
87blyota
08-23-2015 03:57 AM
JustToynAround
08-19-2015 11:46 AM
karbin
07-05-2015 11:37 PM
Quick Reply: Flooding
