flat towing question
Old 01-14-2011, 02:20 PM
xxxtreme22r's Avatar
haha I edited my post the same time you were putting that in Wabbit. lmao. I'd say great minds think alike but you much greater than I and would be an injustice.
Old 01-14-2011, 02:28 PM
it's funny the remco site mentions that an 86-94 4WD manual trans Pickup is towable as is and does not mention the need for the disco.
But and 86-90 auto 4wd needs to be trailered.
And an auto 2wd can use a disco.
Not sure what to think of that.
Old 01-14-2011, 02:42 PM
peow130's Avatar
I know on old jeeps you're not supposed to flat tow because the rear axle bushings get eaten up.
I suppose if you went full floater rear you could flat tow.
Old 08-19-2012, 12:04 PM
ThatGuy1295's Avatar
Tow with the transmission in 4th gear, the t-case in neutral, and leave the engine running.
Old 08-19-2012, 12:08 PM
  #25
Huh ??
Old 08-19-2012, 12:20 PM
  #26
MudHippy's Avatar
Never heard that one before.
Old 08-19-2012, 09:53 PM
  #27
It was meant as a joke, but it would keep oil pumps going. I wouldnt do it, it defeats the whole purpose of towing unless its broken in which case who gives a crap about the god
d-- thing.
Mud hippy, I did some looking, actually oottells, (if thats even a word) of looking, Not only is it suspiciously hard to find good info on this from anything based off toyotas recommendations, but I definetly have not found anything that disagrees with what you have said. If I ever tow my yota very far im definitely going to pull the DL.
Old 08-20-2012, 02:07 AM
  #28
Fossilized
Staff
dropzone's Avatar
Take a look at the t/c input shaft to the left in my avatar. <---
That is what happen when I towed my truck on a dolley and was too lazy to pull the rear d/s on the way after a day of rain wheeling. My crawl box went in low range some how. More pics can be.seen in my build thread some where around aug/sept 2009....Destroying my front crawl box and transmission. $500 reminder, this knowing the t/c bearing don't get lubed correctly.
For the real skinny pm bigmike. Beside risking fubarring your junk the reasons have been explained in other posts...
4x4-runner
04-18-2017 09:08 PM
4x4-runner
08-03-2015 07:14 PM
TJWilly
07-31-2015 02:05 PM
defrag4
07-31-2015 10:50 AM
vanion2
07-29-2015 06:17 PM
Quick Reply: flat towing question
