Fitting 33" tires on 2nd gen 4runner?
Old 02-18-2003, 04:00 PM
fooddude's Avatar
hey i have a 94 4runner and i was wondering what the biggest tire i could fit on it if i got a three inch body lift kit
Old 02-18-2003, 09:14 PM
upndair's Avatar
First, a 3" body lift is generally not very safe, but it is a cheap way to gain tire clearance. You can clear 33's no problem and quite likely 35's
I'd sugest that you go to a shop that sells the tires AND has a ramp. have them put the bigger tires on, run it up the ramp and see if it rubs. Places like 4Wheel Parts will sometimes do stuff like this for you.
Old 02-18-2003, 09:33 PM
Robinhood150's Avatar
Just to clarify, you can fit 33's with a 1inch body lift, crank the torsion bars a little, 1.5 inch lift coils, and cutting the plastic in the wheel well slightly. Better than a 3 inch body lift.
Steve
Old 04-24-2015, 06:34 PM
f2h97's Avatar
33s on 2nd gen 4runner
I have a stock 95 4runner and installed 33x12.50xr15 bf goodrish all terrain tire yesterday, they actully fit with no rubbing at all. By the way im new to the forum.
Old 04-24-2015, 06:55 PM
atlastrekker's Avatar
Steve
This is the way to go, except ball joint spacers are better than cranking the torsion bars.
Old 04-25-2015, 12:28 PM
hotrodchriz's Avatar
I got 33x12.5r15s on a 2in body lift and looks like it clears. Haven't drive It yet due to blown engine and getting ready for engine swap.
Old 04-26-2015, 09:52 AM
bpealer's Avatar
33x12.5 Bj spacers with a little crank and lc coils out back. No body lift.
Old 04-26-2015, 04:06 PM
Damn bpealer, that looks good!!!
I just repainted my wheels today looks better, but not as good as yours! I still plan on installing bj spacers up front and spacers in the rear for another 1 inch or so.
Old 04-26-2015, 05:00 PM
bpealer's Avatar
Thanks. They're getting a little chip with slight surface rust. They look better in the pics. Thinking about powder coating them soon.
Old 04-26-2015, 05:10 PM
Old 04-27-2015, 06:36 AM
n16ht5's Avatar
3" body lifts look terrible in person, and unless you need to clear 44s they are pointless. Run a 1" body lift and do a tummy tuck if you need clearance. Do it right.
06-01-2021 01:51 PM
MMA_Alex
25
04-18-2017 05:07 AM
Jnkml
07-06-2015 01:20 PM
CJ94yota
07-03-2015 10:14 PM
Quick Reply: Fitting 33" tires on 2nd gen 4runner?
