Finally painted the rig! OD green. Write-up with pics!
Old 03-05-2013, 07:50 PM
modot66's Avatar
here is the gallery of all of the pictures: http://imgur.com/a/lvALQ#0
i'm just wrapping up my driveway paintjob and thought i would right a quick article on what i did to help others since i have been helped so much through this site. feel free to post questions and i will answer them when i can. things are drying so i'll add some fresh pics and comments once i get it all put back together.
here are the steps i took:
  1. built a driveway paint booth out of lumber, plastic, and thrift store sheets
  2. took off all emblems and outer trim peices
  3. washed the truck with dawn dish detergent
  4. dried it with a leaf blower
  5. rolled it into the booth
  6. removed all the windows from the doors
  7. removed the tailgate
  8. removed the rear quarter glass. you need to take out the side interior trim panels completely to get to the 11 10mm nuts holding the window in. take a box cutter and slowly cut the glue while pushing out carefully. have a helper on the other side. wear gloves! that glue is nasty and will get on everything. i used 3M adhesive removed to get it off anywhere it dropped
  9. taped and masked the entire truck
  10. wiped entire truck down with wax and grease remover
  11. found some rust in the wheel wells so cut it out then grinded to clean metal
  12. welded in some new sheet metal. my first side i used a crappy harbor freight 90 amp buzz box which was horrible. i borrowed a friend's 220 mig for the other side
  13. used kitty hair then evercoat topfiller to shape the new metal back to contour
  14. feathered body filler out with 150 grit
  15. used a harbor freight palm sander with 3M 320 grit discs to sand down clear coat
  16. cleaned off car with wax and grease remover
  17. using a harbor freight hvlp gun i shot red oxide epoxy primer mixed with epoxy hardener 2:1
  18. after drying i wetsanded the drips out where i didn't dial the gun right. for wetsanding i used a spray bottle of water and some blocks along with soft pads
  19. clean the wetsand up with some axis pre-clean
  20. tack cloth over the truck to clean up dust and debris
  21. shot a coat of epoxy sealer at a ratio of 2:1:1 (primer:reducer:hardener)
  22. let cure overnight
  23. tack cloth the truck again
  24. shoot my first coat of OD green using gillespie ajp ww2 paint with some acrylic enamel reducer and high solids hardener (both napa crossfire brand). the ratio was 8:4:1 (paint:reducer:hardener)
  25. let cure for 3 hours
  26. tack cloth truck
  27. shoot another coat of green
  28. let cure for 3 hours
  29. tack cloth again
  30. shoot final coat
right now the truck is cooking overnight. i'll post more pics when i take the tape off and reinstall trim.
overall the paint looks good. there is some orange peel where i got lazy and some drips i didn't fix completely (again due to laziness). other than that the green looks really good and should hold up well.
some notes:
  • get a good respirator!
  • you don't have to use hardener in the gillespie, but the tests i did without it it seems to take a week or so to become hard enough to not scratch easily. the hardener makes the paint a little more shiny and darker but i think it will hold up better over time to the sun since this paint has no UV protection
  • having a real HVLP gun with a compressor setup would def yield better results than the HVLP turbine i used, but i think it did a good job for a driveway job. i have a compressor but it is only a 35 gallon and i didn't want to mess around with having to wait for it to refill, cycle times, air cleaners, and water traps. this is a truck not a garage queen so i am more than happy with the results
  • use automotive masking tape and sanding sheets only!
hope you get some good info and if you have questions let me know!
Attached Thumbnails Finally painted the rig! OD green. Write-up with pics!-img_1807.jpg
Old 03-07-2013, 05:51 PM
OkieRunner's Avatar
Looks like you did a pretty good job. I like that color. Also admire the do-it-yourself attitude. Saved yourself a few hundred....at least.
Old 03-07-2013, 10:41 PM
wiseguymmiv's Avatar
I'm looking forward to the photos of the final product. I think this color suits the
4Runner well.
Old 03-08-2013, 06:51 AM
modot66's Avatar
More pics
Been raining so haven't had much time to get everything back together but here are some more pics. still want to black out the rest of the chrome trim pieces and get new tires and wheels (if anyone in san diego is looking to buy a nice set of 31x10.50 BFG A/T's with 15" stock rims let me know, they are about a year old and i have receipts).
i'll post more pics this weekend
Old 03-08-2013, 07:26 AM
JBurt's Avatar
Looks great!
Are you going to drive over to El Centro and do mine next? It really needs it.
Old 03-08-2013, 10:42 AM
Stuwy123's Avatar
You should've clearcoated the red primer!
That would've looked sweet! Flat red with a gloss cover!
Old 03-13-2013, 09:54 AM
JBurt's Avatar
Saw your wheels and rims on CL. What are you planning to go with now?
Old 03-13-2013, 03:50 PM
hockey88fan's Avatar
Love it, looks great!
Old 03-13-2013, 03:59 PM
cobolt23's Avatar
I like it!
In a few months, mine will be that color... and dark brown and light green, and maybe some tan thrown in too.
Old 03-13-2013, 07:43 PM
michael1963's Avatar
4Runner well.
Agreed. I think you did a good job, you can't go wrong with OD green!
Old 03-14-2013, 06:30 AM
modot66's Avatar
gonna go with 33's. should be arriving today and will post some fresh pics!
Old 03-14-2013, 06:37 AM
modot66's Avatar
it would be easy for me to paint your truck green since i would be green with envy over the 3.4 and e-locker!
Looks great!
Old 03-14-2013, 06:47 AM
modot66's Avatar
had a few emails about this so figured i would post:
i used one gallon of red oxide epoxy primer and hardener from tcpglobal's "kustom shop". shot a coat of 2:1 primer:hardener. then shot a sealer coat of the same thing only with a medium reducer so the sealer ratio is 2:1:1 primer:reducer:hardener
for paint i used gillespie AJP WW2 semi-gloss OD green ordered from army jeep parts. one gallon was enough. you need to reduce this paint with either xylene or an acrylic enamel reducer. since i live in CA xylene wasn't available so i used napa crossfire reducer CR242.
i also used a hardener which will turn the paint slightly darker and give it more of a sheen but will be tougher and last longer in the sun. up to you if you want to add the hardener. my test panel without hardener took about 4 weeks to get hard enough that i couldn't scratch it with a fingernail.
the hardener i used was napa crossfire ch257. i mixed the paint, reducer, and hardener at a ration of 8:4:1. keep in mind i used an HVLP turbine which puts out hotter air than a traditional compressor setup with cooling lines and dessicants. so depending on what you are shooting with do some tests on those ratios. many people reduce the paint/reducer at 3:1 but i needed a little more reducer due to the hotter air of the turbine.
Old 03-14-2013, 12:51 PM
modot66's Avatar
Fresh pics!
Old 03-14-2013, 01:13 PM
JBurt's Avatar
Nice!
Where did you get your bumpers?
Old 03-15-2013, 02:08 PM
modot66's Avatar
the front is the trailgear mount then my buddy fabbed the rest. rear is the trailgear tube bumper with some custom stuff added
Nice!
Old 03-15-2013, 08:46 PM
Co_94_PU's Avatar
Thanks for sharing! And the mix and equipment details
I've been considering DIY mine. With the HF sprayer(#44677), and a paint kit from tcpglobal. I think you''ve sold me and they're both gonna be oweing you a commision
Old 10-29-2013, 03:31 PM
FinishThaGame's Avatar
Nice rig, and love the Olive Drab paint!!!!
Old 10-29-2013, 03:46 PM
MattWeb's Avatar
sweet
Old 10-29-2013, 03:54 PM
HighLux's Avatar
The dent by the gas door is killing me!!!!
I say you better fix it!! Thats an easy one to pop out!!
All that hard work and it looks great..but Im ocd'ing on the dent.
Let the tribe speak...
BTW bumpers and wheel are pimp. All goes together nice.
Quick Reply: Finally painted the rig! OD green. Write-up with pics!
