Exhaust upgrades on 22re
Old 01-01-2010, 12:59 PM
toyfitter's Avatar
What are some of the exhaust upgrades that you have done on your 22re. And did it make a difference in performance? Headers, Pipe size, ....
Old 01-01-2010, 01:04 PM
kiyobrown's Avatar
I am all stock with an exhaust leak at the manifold and 3 leaks in the muffler. I ordered a full exhaust kit from lce. Header, 2 1/4" cat, and 2 1/4" full exhaust. Might not have it all together for a couple weeks (backordered). But I will keep you posted.
Batt/ intake swap with a supra maf helped with throttle response and maybe 1mpg increase, which has since been erased by the exhaust leak.
Old 01-01-2010, 01:08 PM
AzStorm's Avatar
LCE 2.25" header,cat & muffler and tailpipe.
Made a little difference but nothing to write home about.
It took other mods to go along with the exhaust mod to see and feel a difference.
I think the biggest improvement I noticed on my 22re has been the overbore throttle body and matched bore intake.
A motor is essentially an air pump.The more air it pumps the more power it makes.
Old 01-01-2010, 01:12 PM
BigBluePile's Avatar
This has been covered at LEAST once...let me search around on here for YOU. I'll post up in a minute...
Old 01-01-2010, 01:14 PM
kiyobrown's Avatar
It has? I'm not too sure about that Logan.... Although you MIGHT be trustworthy enough to believe.
Old 01-01-2010, 01:20 PM
I'm still searching...I'll post links soon...
Old 01-01-2010, 04:07 PM
kiyobrown's Avatar
Originally Posted by Gnarly4X
Oh my gawd@!!!
Exhaust upgrades... OK let's do it@!@!
I think that a Doug Thorely header with 2.25" exhaust, and a free flow muffler is as good as it gets. You should see about a 10% gain in HP on a healthy stock 22RE. You will probably lose just a tad of torque from off-idle to around 2,000 RPM, but you'll see a nice increase in throttle response from there up.
TJMWO,
gNARLS.
perfect, do that setup, then we can trade rigs and see if one is better then the other.
06-01-2021 01:51 PM
RatOmeter
10-22-2015 03:17 PM
garagespace
10-11-2015 10:59 AM
RobotMoose
Diesel Swaps
08-02-2015 11:00 PM
Quick Reply: Exhaust upgrades on 22re
