exhaust manifold studs
Old 04-12-2011, 03:59 PM
shaunneuhaus95's Avatar
i searched and couldnt find. i gotta 22re exhaust manifold studs that have pulled the threads. i gotta good idea what im gonna do to fix it, but i was looking for a thread so i can compare ideas
Old 04-12-2011, 04:19 PM
justin_4runner's Avatar
u can just drill it and tap it for a heli coil or drill and tap for a bigger bolt,
Old 04-12-2011, 04:35 PM
rpij137g's Avatar
I like the drill and tap a larger hole idea.
Old 04-12-2011, 11:42 PM
wyoming9's Avatar
Red face
I have great luck with thread replacement inserts then using new studs of the same size.
Most times when you are at this point the head is coming off most often so it is much easier to do the drilling in a drill press. At least for me as I would fall into the engine compartment and need to be rescued again
Old 04-13-2011, 04:33 AM
waskillywabbit's Avatar
Fix it properly and replace all the studs while you are there.
:wabbit2:
Old 04-13-2011, 06:18 AM
ok so after i posted this and did some more reading, the owner of the truck i was gonna do this work on sends me pics of the issue. Its not the exhaust manifold studs that are pulled out of the head, its the 3 studs that connects the rest of the exhaust to the manifold. GRRRRRRR!!! next time ill just ask for pics 1st
Streetrod19772000
09-10-2015 06:22 PM
Obmi
09-10-2015 03:36 AM
idadan208
09-07-2015 09:06 AM
May-39
09-06-2015 01:05 PM
Quick Reply: exhaust manifold studs
